pendergrass
- Apr 18, 2014
dont know if it might be a bug or i missed something...
I m facing this problem on 9.2.1.5 as well as on 9.2.2 Alpha NB (04/30).
Tried to install SabNZBd. Installation went good without any worrying logs.
As soon as it starts i m getting the last 3 messages of the log below. I copied the whole log after restarting the jail again.
Running FreeNAS on ESXi 5.5, 6gb ram, IBM M1015 (IT mode) pass-through..., one NIC (not pass-through)
I'm not able to ping the assigned ip address, although my network monitoring is showing me that a new machine with this ip joined the network after first installation/start of plugin/jail
Can anyone help me with this?
Br
Br
May 1 08:33:34 freenas kernel: ifa_del_loopback_route: deletion failed May 1 08:33:34 freenas kernel: Freed UMA keg (udp_inpcb) was not empty (10 items). Lost 1 pages of memory. May 1 08:33:34 freenas kernel: Freed UMA keg (udpcb) was not empty (168 items). Lost 1 pages of memory. May 1 08:33:34 freenas kernel: Freed UMA keg (tcptw) was not empty (50 items). Lost 1 pages of memory. May 1 08:33:34 freenas kernel: Freed UMA keg (tcp_inpcb) was not empty (10 items). Lost 1 pages of memory. May 1 08:33:34 freenas kernel: Freed UMA keg (tcpcb) was not empty (8 items). Lost 2 pages of memory. May 1 08:33:34 freenas kernel: hhook_vnet_uninit: hhook_head type=1, id=1 cleanup required May 1 08:33:34 freenas kernel: hhook_vnet_uninit: hhook_head type=1, id=0 cleanup required May 1 08:34:14 freenas notifier: Performing sanity check on nginx configuration: May 1 08:34:14 freenas notifier: nginx: the configuration file /usr/local/etc/nginx/nginx.conf syntax is ok May 1 08:34:14 freenas notifier: nginx: configuration file /usr/local/etc/nginx/nginx.conf test is successful May 1 08:34:14 freenas kernel: bridge0: Ethernet address: 02:71:77:6c:01:00 May 1 08:34:14 freenas kernel: bridge0: link state changed to UP May 1 08:34:14 freenas kernel: em0: promiscuous mode enabled May 1 08:34:14 freenas kernel: epair0a: Ethernet address: 02:50:7c:00:05:0a May 1 08:34:14 freenas kernel: epair0b: Ethernet address: 02:50:7c:00:06:0b May 1 08:34:14 freenas kernel: epair0a: link state changed to UP May 1 08:34:14 freenas kernel: epair0b: link state changed to UP May 1 08:34:14 freenas kernel: epair0a: promiscuous mode enabled May 1 08:34:14 freenas kernel: ng_ether_ifnet_arrival_event: can't re-name node epair0b May 1 08:34:15 freenas mDNSResponder: mDNS_Register_internal: ERROR!! Tried to register AuthRecord 0000000800C2FD60 freenas.local. (Addr) that's already in the list May 1 08:34:15 freenas mDNSResponder: mDNS_Register_internal: ERROR!! Tried to register AuthRecord 0000000800C30180 52.0.168.192.in-addr.arpa. (PTR) that's already in the list
