I have been trying to figure out how to have multiple plugins run inside 1 jail. I have created a standard jail template and used 'pkg' to install several plugins (radarr, sonarr, nzbget, transmission, and plex-pass) but run into an issue when I try to add a movie or TV show, it says 'admin user cannot write to folder'.
Following the guide here (https://forums.freenas.org/index.ph...plugins-write-permissions-to-your-data.27273/), I have created a user/group called admin with ID 1001. I followed solution #3 but doesn't seem to work. I then tried to implement solution #2 by creating an user/group with UID to match the plugins (816) but that doesn't seem to work either.
Side note, I did try solution #4 which does work but this also opens plex users to be able to delete files which I don't want anyone using my plex server to be able to do. Also I am unable to create a 'media' user to match the plugins user since there is already one present which I never created (see picture)
I have attached several pictures for my storage as well permissions for each of the datasets to give you an idea of what they are. Currently they show 'root' as user and 'wheel' as group but I have changed them to admin/admin but nothing seems to work. I haven't changed my permissions to jails, just to throw it out there.
Any help to fix these permissions issue would be greatly appreciated. I have deleted and reinstalled all plugins like 20 times just to get the permissions for all plugins to work together.
Thanks
Thanks
