Suiname
 - Dec 5, 2012
I posted this in the plugins section and got no response, I suspect this is actually a networking problem though so I thought I'd cross-post here, hope that is allowed.
I've been trying to install plugins for some time now and unfortunately my jail never gets an IP. I've already looked through the forum and unfortunately all the common fixes were no help to me. So far I've done the following troubleshooting steps - uninstall / reinstall the plugin pbi, assign several different IPs, manually input the router IP into the default gateway and nameserver fields in the network configuration settings. So far none of these have helped. My router IP is 192.168.1.254 (it's a combo DSL modem / router from at&t). This is a physical box with the OS installed on a USB key. If anyone has anything that could help, it would be greatly appreciated.
Here is the ifconfig of my freenas box:
And the netstat:
Here is the ifconfig of my jail:
Also of note, I looked at the device settings on my router, and it shows that IPs 192.168.1.142 and 192.168.1.144 are being used (those are the IPs of my Freenas Box and the Bridge0 respectively). It also shows that at one point the DHCP leased out 192.168.1.143 to a MAC that doesn't exist anymore (probably because I've deleted / recreated the jail like 15 times at this point). Can someone explain to me what Bridge0 is for anyways?
em0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=42098<VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,VLAN_HWTSO> ether 00:01:2e:2f:10:be inet 192.168.1.142 netmask 0xffffff00 broadcast 192.168.1.255 media: Ethernet autoselect (1000baseT <full-duplex>) status: active lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> metric 0 mtu 16384 options=3<RXCSUM,TXCSUM> inet6 fe80::1%lo0 prefixlen 64 scopeid 0xa inet6 ::1 prefixlen 128 inet 127.0.0.1 netmask 0xff000000 nd6 options=3<PERFORMNUD,ACCEPT_RTADV> bridge0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether 02:fe:4a:c8:9c:00 inet 192.168.1.144 netmask 0xffffff00 broadcast 192.168.1.255 id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 100 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: em0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 1 priority 128 path cost 20000 member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 12 priority 128 path cost 2000 epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8<VLAN_MTU> ether 02:56:1a:00:0c:0a inet 0.0.0.0 netmask 0xff000000 broadcast 255.255.255.255 media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active bridge1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500 ether 02:fe:4a:c8:9c:01 id 00:00:00:00:00:00 priority 32768 hellotime 2 fwddelay 15 maxage 20 holdcnt 6 proto rstp maxaddr 100 timeout 1200 root id 00:00:00:00:00:00 priority 32768 ifcost 0 port 0 member: epair1a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP> ifmaxaddr 0 port 14 priority 128 path cost 2000 epair1a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500 options=8<VLAN_MTU> ether 02:aa:8e:00:0e:0a inet 0.0.0.0 netmask 0xff000000 broadcast 255.255.255.255 media: Ethernet 10Gbase-T (10Gbase-T <full-duplex>) status: active
And the netstat:
[jt@freenas] ~> netstat -rn Routing tables Internet: Destination Gateway Flags Refs Use Netif Expire 0.0.0.0/8 link#12 U 0 0 epair0 => default 192.168.1.254 UGS 0 6 em0 127.0.0.1 link#10 UH 0 32719 lo0 192.168.1.0/24 link#1 U 0 92984 em0 192.168.1.142 link#1 UHS 0 137 lo0 192.168.1.144 link#11 UHS 0 0 lo0 Internet6: Destination Gateway Flags Netif Expire ::/96 ::1 UGRS lo0 ::1 link#10 UH lo0 ::ffff:0.0.0.0/96 ::1 UGRS lo0 fe80::%lo0/64 link#10 U lo0 fe80::1%lo0 link#10 UHS lo0 ff01::%lo0/32 fe80::1%lo0 U lo0 ff02::%lo0/32 fe80::1%lo0 U lo0
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
epair1b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=8<VLAN_MTU>
        ether 02:aa:8e:00:0f:0b
        inet 192.168.1.143 netmask 0xffffff00 broadcast 192.168.1.255
        inet6 fe80::aa:8eff:fe00:f0b%epair1b prefixlen 64 scopeid 0x2
        status: active
