Jackett WebGUI "refused to connect
Chopper3280
I have manually installed Jackett on my TrueNas release 13.2 in its own jail. I've followed 4 or 5 differing guides but when I try to access the Jackett webgui on port 9117 I get the following error;
This site can’t be reached​
10.0.1.11 refused to connect.
Try:​
  • Checking the connection
  • Checking the proxy and the firewall
ERR_CONNECTION_REFUSED
I have confirmed that the jacket service is started, I have tried with NAT, without NAT, and I always get the same error.
I have also tried release 12.4 and release 13.1, again with the same error message.
Currently Jacket is configured with an IP of 10.0.1.11 at port 9117 and I even tried adding a port forwarding rule in my router.
I'm pretty much at a loss as to what else to try and any advice would be gratefully received.
Cheers.
5hiftyy
I'm running into the same issue. Did you ever get this resolved?
Chopper3280
@5hiftyy, Nope no luck at all. I also contacted Steve from Blackbeard support on you tube but haven't had any response from him. Steve has some great tutorials, and this is the first time I've followed his instructions without actually being able to connect.
Bjornzi
I have the exact same issue, no solution.
