- Aug 16, 2011
Plugins are broken. We all know it, and you have no intention of fixing them. Most notably, @Kris Moore has said not to use them, and that they're "more or less deprecated":
And users see it:
www.truenas.com
www.truenas.com
www.truenas.com
www.truenas.com
www.truenas.com
www.truenas.com
www.truenas.com
But you're still pretending they're a real, usable thing:
www.truenas.com
You're being dishonest with your (prospective) users, and expecting us to pick up the pieces. It's getting more than a little frustrating. And while I'm focusing on Nextcloud above (partially because, less than a year ago, you made a big deal about your partnership with Nextcloud that would, you said, make the plugin not suck; and partially because I've spent a lot of time making Nextcloud work on CORE), the same is true of the rest of them (Asigra, another one you made a big deal about, seems to be abandonware from your perspective as well).
When are you going to be honest with your users and prospective users, and stop pretending that plugins are viable or usable for any purpose?
This isn't the first time you've been asked about this; see:
www.truenas.com
www.truenas.com
using plugins on CORE is a path to sadness. The plugin system is more or less deprecated and as you can tell, somewhat unstable.
The plugin system on CORE is for all intents and purposes deprecated and in pretty rough shape right now,
And users see it:
NextCloud plugin
I have installed TrueNAS-13.0-RELEASE but with great regret NextCloud is not installed: "pkg error: - nginx: Refusing to fetch artifact and run post_install.sh! Partial plugin destroyed" ... any ideas? thanks immensely.
Unable to install NextCloud plugin.
I an unable to install the Nextcloud plugin. "Error: NextCloud had a failure Exception: RuntimeError Message: pkg error: - nginx : Refusing to fetch artifact and run post_install.sh! Partial plugin destroyed". I recently upgraded to TrueNAS-13.0-RELEASE.
Error with Getting CA Private Key while installing Nextcloud Plugin
I have already tried to install Nextcloud several times. But I always get the following error message: nextcloud had a failure Exception: RuntimeError Message: Last 10 lines: Getting CA Private Key mysqladmin: [Warning] Using a password on the command line interface can be insecure. Warning...
Nextcloud plugin installation issue
Hi again, I am receiving this error "Error: Nextcloud had a failure Exception: RuntimeError Message: Last 10 lines: Partial plugin destroyed" Fresh TrueNAS installation, the only other plugin installed is plex. I tried multiple times, overright the same plugin, resetting my pool, new usb drive...
Plugins not installing on true nas
I am running true NAS in a hyper v VM to test its functions and to see if i can use it as my main server to do everything I need a server to do "Unifi server for work, pi hole for my internet, home bridge so i can have more things in home kit on my phone and a windows VM so I can remote in and...
Unable to Update Plex
Hi there I went to update the Plex Plugin and the following happen Error: Cmd('git') failed due to: exit code(128) cmdline: git clone -v https://github.com/freenas/iocage-plugin-plexmediaserver.git /mnt/Candace/iocage/jails/Plex/plugin stderr: 'Cloning into...
Who manages plugin updates? (Syncthing)
Version is 1.18.1 and that came out quite a long time ago. Is there a simple button to click and it deploys a new version somewhere, or is there more to it than that? I'd prefer to use my docker server but I'm trying to diagnose some strange behaviour.
Blog - Nextcloud and TrueNAS Collaborate to Help You Build Your Private Cloud
Today we are announcing a partnership with Nextcloud to provide an officially supported integration with TrueNAS. Nextcloud and TrueNAS are the #1 Open Source platforms for team collaboration and software-defined storage, respectively. The Nextcloud software suite will plug into TrueNAS and both...
Just A Rant, Emby Plugin Update
Every... Single.... Time... I try to update any jail or plugin in any way, it doesn't work as expected. I have the Emby plugin installed and running fine in a 12.2-RELEASE-p13 jail on TrueNAS 13.0-RELEASE. TrueNAS tells me there is an update available, I stop the plugin and click the...
