No and turn off compression, if enabled, during the test. The dd commands you should be using are the ones in the [thread=981]performance sticky[/thread].
Thanks for the link. I swear I searched but I didn't come across that page. I'll gather some info when the SMART test is finished running. I have compression off right now.
How about the manpage? Don't forget to specify the proper device.
Reconfigure it at least. ZFS can make better decisions when it knows how many disks it's dealing with. If the RAID card has a write cache with a BBU and you want to take advantage of it that's fine. If it doesn't then there's no reason I can think of to use it.
I used the commands from that page but couldn't get anything to work with the RAID card installed. I had also read I needed to use different commands for the LSI based card but couldn't get any results with that command set either. So I've since removed the card and now everything is working, command line wise, as it should.
Thank you for the help.
