SOLVED It seems that i don't have any hard drives
Mirfster
Ernie411
Oops, that went a bit wrong.
That was a mistake. I've re-entered the same text again and deleting wouldn't work So i entered there: Oops, that went a bit wrong.
But i've interrupted the formatting but i can't format the drive in FAT32.
Only in NTFS.
There's no need for you to format anything. There's really no need to even remove the partition tables at this point (though that will probably be necessary before you can actually add the drives to a pool). The problem is that FreeBSD isn't seeing the drives at all, which is likely due to either outright hardware incompatibility or improper BIOS settings. A Linux distro will help narrow down the issue. It isn't dispositive, as the HCLs are quite different between Linux and FreeBSD, but it will at least give a data point.
Ernie411
So i ran gparted.
No problem what so ever.
But still no hard drives in FreeNAS.
I'll give up.
Mirfster
BigDave
FreeNAS Enthusiast
Just double checking here...
In the board's bios, you have the SATA controller set to AHCI correct?
BigDave
FreeNAS Enthusiast
Mirfster
BigDave
FreeNAS Enthusiast
P.S. I want partial credit too... :p
Yes, it was your post about the controller may not be enabled thing that got me to go
back to the start of the thread. With no mention of AHCI, it was the only thing left...
Ernie411
Yes, that's it.
Yet another problem.: i am unable to make a domain.
Should it be Active Directory or LDAP or NIS or NT4?
Mirfster
New thread please and include more info; like what you are wanting to do and what you have done. Perhaps in the "User Authentication" Section of the Forums.
*** But before doing that, please search the forums and the Manual
Ernie411
Never mind.
It was my mistake.
After reading the manual things sorted out.
Thanks guys for all the help.
