Firstly i am testing out Truenas Core to replace an SOHO solution for a potential client. tbf this is my first approach at Truenas and i think i am in way over my head.
i am testing this at my home server (details below) and i keep getting the same error messages that appear to be caused by AHCI with timeouts and eventually detaching the drives, therefore offering no stability. below you can find some snippets of the errors plus a partial console log of the last time the error occurred.
For reference, i am using a small server to test the solution that has proxmox installed and a separate PCI controller to connect the HDDs. I tried to look around in this forum and others and all the possible solutions i found none work. this is not my speciality and as i am doing this to a friend who might be a potential customer i am trying to figure this out.
- ASRock B550M-ITX/ac
- AMD Ryzen 5 4600G
- 32Gb (16 allocated to the VM)
- WD2000FYYX; WD20EADS-00R6B0; ST2000DM008; ST2000DM008; ST2000DM008 - ZFS z1 - boot drive is a vm hdd
- JMB58x controller
- Virtualized
- Running Proxmox as the main OS and virtualized TrueNAS-13-0-U6.1
Jan 3 17:26:54 truenas.local ahcich2: Timeout on slot 24 port 0
Jan 3 17:26:54 truenas.local ahcich2: is 00000000 cs 02000000 ss 03000000 rs 03000000 tfd 40 serr 00000000 cmd 00449817
Jan 3 17:26:54 truenas.local (ada2:ahcich2:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 80 d0 bf 3a 40 19 00 00 06 00 00
Jan 3 17:26:54 truenas.local (ada2:ahcich2:0:0:0): CAM status: Command timeout
Jan 3 17:26:54 truenas.local (ada2:ahcich2:0:0:0): Retrying command, 3 more tries remain
Jan 3 17:28:25 truenas.local ahcich4: Timeout on slot 18 port 0
Jan 3 17:28:25 truenas.local ahcich4: is 00000000 cs 00040000 ss 00000000 rs 00040000 tfd 150 serr 00000000 cmd 00448017
Jan 3 17:28:25 truenas.local (aprobe4:ahcich4:0:0:0): ATA_IDENTIFY. ACB: ec 00 00 00 00 40 00 00 00 00 00 00
Jan 3 17:28:25 truenas.local (aprobe4:ahcich4:0:0:0): CAM status: Command timeout
Jan 3 17:28:25 truenas.local (aprobe4:ahcich4:0:0:0): Error 5, Retry was blocked
Jan 3 17:28:25 truenas.local ada4 at ahcich4 bus 0 scbus4 target 0 lun 0
Jan 3 17:28:25 truenas.local ada4: <WD2000FYYX 00.0D1K2> s/n WCC1P0106986 detached
Jan 3 17:28:25 truenas.local GEOM_MIRROR: Device swap1: provider ada4p1 disconnected.
