Issues replacing failed disk.
onthax
Running Truenas Scale and had disks fail across multiple volumes.
Running RaidZ2 so no worries there.
Offlined the failed disks, replaced (hotswap enclosure) one of the disks with a replacement disk.
when i go into the volume, select a failed disk and go replace disk, it's not coming up with any disks to replace.
If i go and try to create a pool i see the 3 disks (1 replacement and 2 failed offline disks)
Models are the same as vendor replaced the failed disk and it's showing in the Lenovo IMM
Any ideas?
Half tempted to replace at the CLI but not sure if this will cause issues in the gui later.
  pool: volume01
 state: DEGRADED
status: One or more devices has been removed by the administrator.
        Sufficient replicas exist for the pool to continue functioning in a
        degraded state.
action: Online the device using zpool online' or replace the device with
        'zpool replace'.
  scan: scrub repaired 0B in 1 days 00:35:47 with 0 errors on Mon Jul 24 00:35:49 2023
        NAME                                      STATE     READ WRITE CKSUM
        volume01                                  DEGRADED     0     0     0
          raidz2-0                                DEGRADED     0     0     0
            8fc8ff15-ae35-46ec-bb39-1104f0194b4e  ONLINE       0     0     0
            189c9326-b5f6-4b31-9d6f-2269c756d787  ONLINE       0     0     0
            62df029e-3101-4e4c-9d26-798a258df9ea  ONLINE       0     0     0
            ca99543d-b5e8-4af9-a30a-c389072d04b9  ONLINE       0     0     0
            742591ac-077d-427d-80b1-c3afceb60d63  ONLINE       0     0     0
            701be8f1-8970-4744-ab8d-fdcbc106ab63  ONLINE       0     0     0
            2f804d70-b531-4971-9e25-a86bcdffbf8b  ONLINE       0     0     0
            c0618ede-c8fc-4dce-b565-daf565d086bd  ONLINE       0     0     0
            eaefb279-169c-4502-b656-0c77818b5a8f  ONLINE       0     0     0
            8d782cbc-602e-422e-939d-190f2d73aae7  ONLINE       0     0     0
            bf669490-5f4c-4b53-b11e-dc742e01d61b  ONLINE       0     0     0
            2e424240-7092-4423-ab57-a33f0c93de1e  ONLINE       0     0     0
            fd86335b-b8aa-4e32-9c89-3680c82059fa  ONLINE       0     0     0
            6e85295f-ae89-44f3-9eee-1413e56156e9  ONLINE       0     0     0
            2f47643f-205d-477c-b961-9ec39eae5006  ONLINE       0     0     0
            3e28294a-aba0-41c0-8da5-9272c205fe8f  ONLINE       0     0     0
            969b4fd7-d63e-4796-bd09-2470bea6787e  ONLINE       0     0     0
            d5157b11-6f07-447b-a495-e27e1a043340  ONLINE       0     0     0
            b141280d-4d76-4e39-9342-ea142a8b24fd  ONLINE       0     0     0
            991987f2-319d-4a26-998d-065ec0da4893  REMOVED      0     0     0
            d7f1c256-94d3-42e4-8519-fdb41a30bc18  ONLINE       0     0     0
Original Disk:
root@fj03ns01[/home/admin]# parted /dev/sdag
GNU Parted 3.4
Using /dev/sdag
Welcome to GNU Parted! Type 'help' to view a list of commands.
(parted) p
Model: LENOVO-X ST14000NM002G (scsi)
Disk /dev/sdag: 14.0TB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Disk Flags:
Number  Start   End     Size    File system  Name  Flags
 1      65.5kB  2147MB  2147MB                     swap
 2      2148MB  14.0TB  14.0TB  zfs
Replacement disk:
parted /dev/sday
GNU Parted 3.4
Using /dev/sday
(parted) p
Error: /dev/sday: unrecognised disk label
Model: LENOVO-X ST14000NM004J (scsi)
Disk /dev/sday: 14.0TB
Partition Table: unknown
Disk Flags:
(parted)
indivision
This isn't normal from my experience. You should see the new disks once they are plugged in and you power on.
Obviously, double check everything about how those disks are powered and connected.
But, if it were me, I would not be looking for a workaround. I would view this as a red flag that something needs to be fixed so that the software sees the disks before taking next steps.
onthax
disks appeared in the replace after reboot.
Resilver is running now.
have raised a jira ticket, as i expect this isn't desired behaviour.
