Issues loading freenas onto 120gb hard drives (JSONDecodeError)
AlanJask
I started the installation process with 2 120gb hard drives, I re-wiped them so there wasn't a half installed version of freeNas on it.
Its a newbie question, any suggestions?
Image attached
ethereal
two things
1. you should provide details of you hardware as per forum rules.
2. have you tried installing to a single usb flash drive ?
AlanJask
Hi Ethereal,
Thanks for the tips I am new to the forum.
I have not tried a single flash drive yet. I will test that out today.
MBD-X10SRL-F
Xeon E5-1620v4
64gb Samsung M393A2G40DB0-CPB
24 x 8tb WD Red Drives
Boot Disks 2x 120gb Sandisk
IBM M1015 HBA IT FLASHED
PSU 0 2x SuperMicro PWS-920P-SQ
Backplane - SuperMicro BPN-SAS-846A
Intel Ethernet Converged Network Adapter X540-T2
Chassis - SAS846TQ
ethereal
so the sandisks are ssd not hdd ?
how are the attached - to the hba or m/b ?
AlanJask
Yeah they are SSD attached to m/b. I just tried a usb drive and got the same error...
ethereal
it's been years since i did an fresh install - but i believe there are 2 ways to install.
uefi - i think and another - have you tried both ?
it could also be something in your bios
ethereal
also i would try and download the freenas image again and make sure it is burned correctly - some software doesn't burn correctly
AlanJask
I wasn't able to boot uefi successfully, probably user error. The Legacy boot seemed to work till I got the error. I tried burning it again on a 8gb flash. I have two 64gb flash drives but they seem like they aren't readable. Maybe I should pick up a few different flash drives?
I can look at the bios, any links on hand of what the bios settings should be?
ethereal
i don't know anything specific to look for in the bios - just another place for you to look.
MrToddsFriends
Documentation Browser
AlanJask
I figured it out! I picked up some new flash drives. That must of been the issue.
Thanks for all of the suggestions.
