ISCSI question, looking to add second volume to 2nd interface and init from separate server
VirtualUman
I am looking to add a second volume to the 2nd freenas interface and init iscsi connection from a separate server than the first volume.
I cannot get my second volume to mount with a different port, or different ip address on the other interface, and when connecting through iscsi, I only see the first volume I set up.
Can someone please point me in the right direction? I am pretty sure this is either not supported or my settings are off in freenas.
VirtualUman
Found my problem! After making changes to the ISCSI settings, and targets.. I needed to reboot for my changes to show?
This solved my problem so I guess so, I am running Version 8.2.0
