iSCSI overload???
Ikon
I recently installed iSCSI on my server an started installig games on the server, but after 1-2 minutes my pc(most programs) freezes and it takes about 1 minutes before it "unfreezes" and I can see the disk(iSCSI share) on task manager goin 100%.
Any help would be great.
Samuel Tai
Details of your server hardware, please, per the Forum Rules.
Samuel Tai
What are the model numbers of your Red drives? I suspect you may be running SMR drives, which would exhibit this performance pattern.
Ikon
Got some photos here:
Samuel Tai
OK, they're the CMR models, so that's not a problem. How is your pool constructed? For iSCSI, you'll want to use mirrors instead of RAIDZx. Also, you have less than the minimum required RAM of 16 GB.
Ikon
I don't care so much about my data on the nas so i use raid1 if that works?
Can try to install more RAM.
Thanks
Samuel Tai
Yes, you'd get the best performance with a 4-way stripe over these 4 disks. For iSCSI, you'll also want to use jumbo frames and configure TCP cubic.
Ikon
Will do!
Thanks for your help
Samuel Tai
Check out this thread from someone in a similar situation as yours. Note, he has much faster hardware.
Ikon
I just installed 24gb of RAM but one of my motherboard wont detect one of my 8gb stick?
Do you know how to fix it?
It did work with my 2gb stick.
jgreco
Resident Grinch
The minimum required RAM for iSCSI is generally significantly greater, such as 64GB, or for trite uses, 32GB may work. See:
Without sufficient RAM, both the write cache (this ISN'T the SLOG/ZIL) will have trouble assembling large transaction groups, and the read cache suffers for all the reasons discussed in the linked article. Both of these will cause poor performance.
Samuel Tai
Check your motherboard manual for RAM compatibility. Sorry, this is something specific to your board and RAM combo.
Samuel Tai
OK, this is because of your CPU memory controller. They typically have a hard time with unequal stick sizes. Try it with just the 2x8GB sticks. You'll need to trade your 4x2GB sticks for more 8GB sticks.
Ikon
I have 4x32gb sticks bur they are ddr4, my motherboard uses ddr3
Samuel Tai
Ikon
When I was going to check on my server this was at my screen.
Don't know if this is normal or is a part of the problem?
Davvo
jgreco
Resident Grinch
That's not normal and looks like a network issue.
It's not a network issue. iSCSI has a five second timeout, and if operations are not being served expeditiously, you will get these kind of timeouts.
RAM: 12gb
If you are pushing lots of traffic at the server with iSCSI on only 12GB RAM, I'd say this is totally expected. After awhile, the system suffers fragmentation and starts to suffer from an inability to rapidly allocate new blocks for writes, which tends to cause iSCSI to freak out.
