SwisherSweet
 - May 13, 2017
I have setup two zvols:
1. machine1-backup
2. machine2-backup
#1 zvol will be attached to "machine1" Windows VM.
#2 zbol will be attached to "machine2" Windows VM.
I have successfully gotten #1 to work by:
1. Created a Portal (IP not specified; only 1 IP on FreeNAS server)
2. Created a Target using the initiator name from the "machine1" iSCSI config
3. Created an Extent called "machine1-backup", selecting the zvol device "machine1-backup" and leaving all other settings default.
4. Associated the extent and target from the steps above under "Associated Targets"
I was then able to see the target in Windows under the "Targets" tab in iSCSI Initiator, mount the disk and use it fine.
However, I cannot get the second VM to connected using the same steps. Here's what I did for the second:
1. Used the same Portal from the first Machine. I assume this is correct?
2. Created a Target using the initiator name from the "machine2" iSCSI config
3. Created an Extent called "machine2-backup", selecting the zvol device "machine2-backup" and leaving all other settings default.
However, unlike "machine1", I am unable to see the target under the "Targets" tab in iSCSI Initiator.
Note, the VMs are NOT on FreeNAS. They are running on a Mac Server on the same local network.
Does anyone know what step(s) I may be missing?
			1. machine1-backup
2. machine2-backup
