iSCSI and VMware latency
orddie
Running TrueNAS-SCALE-22.12.0
Two ESXi hosts with single AMD EPYC 7252 8-Core Processor, 255GB ECC memory.
One Truenas server AMD Ryzen 7 3700X 8-Core Processor, 128GB ECC memory
Disk layout
- 8 1.92 TB SSD's configured in 4 mirror v-dev's
- no Log, cache, or Dedupconfigured.
Hosts are directly connected to one another via Mellanox MCX314A-BCCT 40Gb Ethernet
Each hosts show links are up and no line errors according to operating system.
Host A's IP is 10.255.255.9/29
TrueNas IP for host A is 10.255.255.10/29
Host B's IP is 10.255.255.17/29
TrueNas IP for host B is 10.255.255.18/29
Ping works as expected
MTU set to 9000 and confirmed PING works via ping -s 9000 from/to each host
Pool is sitting at 45% consumed.
Seeing latency just under 300 and iOPS of sub 1000
what can be done to improve performance.
Run TrueNAS CORE for iSCSI workloads as recommended by iX.
jgreco
Resident Grinch
If you're running SCALE, this gives you the bare minimum ARC recommended for iSCSI (64GB). Try quadrupling the RAM, or running CORE and doubling it, AT A MINIMUM.
Not particularly recommended hardware. Try a Chelsio T580-CR.
MTU set to 9000
Probably get rid of this idiocy. See link. Let hardware offload do the work, especially when using marginal/dodgy hardware like Mellanox. This implies switching to recommended chipsets like Intel or Chelsio with offload known to work well.
I don't even have any idea WTF you think that's doing for you.
That's not terrible, at least, but it will interact poorly with the low ARC to slow down metaslab searches for free space. "Slow writes."
So you have four vdevs on 40GbE so you are expecting perhaps 10Gbps performance out of each vdev. That seems unlikely. Not impossible.
Yeah, I bet you are. You should be using CORE for iSCSI and that change alone would probably be very impactful. Perhaps also make sure you've read through:
orddie
Swapped over to TureNas core and import the pools. That went OK. Still very slow speeds when testing.
I then thought to do an FIO test on the pool directly. The following command never completes. Thinking I have another issue in my system that causes this.
fio --filename=test --direct=1 --rw=randrw  --randrepeat=0 --rwmixread=100 --iodepth=128 --numjobs=12 --runtime=60 --group_reporting --name=4ktest --ioengine=psync --size=4G --bs=4k
orddie
I destroyed the dataset and re-created it. During that process, Truenas sent an alert about a disk issue so that's been replaced.
now I'm getting about 101k IOPS and 400ish MB/s for reads and writes.
writes
4ktest: (g=0): rw=randrw, bs=(R) 4096B-4096B, (W) 4096B-4096B, (T) 4096B-4096B, ioengine=psync, iodepth=128
fio-3.28
Starting 12 processes
4ktest: Laying out IO file (1 file / 4096MiB)
Jobs: 12 (f=12): [r(12)][100.0%][r=393MiB/s][r=101k IOPS][eta 00m:00s]
4ktest: (groupid=0, jobs=12): err= 0: pid=8181: Wed Jan 18 18:23:29 2023
  read: IOPS=101k, BW=393MiB/s (412MB/s)(23.0GiB/60002msec)
    clat (nsec): min=1142, max=2033.2k, avg=115234.72, stdev=54456.22
     lat (nsec): min=1173, max=2033.4k, avg=115657.83, stdev=54512.98
    clat percentiles (usec):
     |  1.00th=[    7],  5.00th=[   11], 10.00th=[   16], 20.00th=[   92],
     | 30.00th=[  101], 40.00th=[  110], 50.00th=[  123], 60.00th=[  137],
     | 70.00th=[  147], 80.00th=[  155], 90.00th=[  165], 95.00th=[  174],
     | 99.00th=[  208], 99.50th=[  269], 99.90th=[  510], 99.95th=[  578],
     | 99.99th=[  840]
   bw (  KiB/s): min=319881, max=561475, per=100.00%, avg=403066.91, stdev=5629.87, samples=1416
   iops        : min=79965, max=140366, avg=100762.93, stdev=1407.46, samples=1416
  lat (usec)   : 2=0.01%, 4=0.06%, 10=4.01%, 20=8.58%, 50=2.20%
  lat (usec)   : 100=14.05%, 250=70.50%, 500=0.49%, 750=0.09%, 1000=0.02%
  lat (msec)   : 2=0.01%, 4=0.01%
  cpu          : usr=4.26%, sys=95.71%, ctx=15540, majf=0, minf=0
  IO depths    : 1=100.0%, 2=0.0%, 4=0.0%, 8=0.0%, 16=0.0%, 32=0.0%, >=64=0.0%
     submit    : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0%
     complete  : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0%
     issued rwts: total=6040028,0,0,0 short=0,0,0,0 dropped=0,0,0,0
     latency   : target=0, window=0, percentile=100.00%, depth=128
Run status group 0 (all jobs):
   READ: bw=393MiB/s (412MB/s), 393MiB/s-393MiB/s (412MB/s-412MB/s), io=23.0GiB (24.7GB), run=60002-60002msec
Reads
fio --filename=test --direct=1 --rw=randread  --randrepeat=0 --rwmixread=100 --iodepth=128 --numjobs=12 --runtime=60 --group_reporting --name=4ktest --ioengine=psync --size=4G --bs=4k
4ktest: (g=0): rw=randread, bs=(R) 4096B-4096B, (W) 4096B-4096B, (T) 4096B-4096B, ioengine=psync, iodepth=128
fio-3.28
Jobs: 12 (f=12): [r(12)][100.0%][r=394MiB/s][r=101k IOPS][eta 00m:00s]
4ktest: (groupid=0, jobs=12): err= 0: pid=8203: Wed Jan 18 18:24:39 2023
  read: IOPS=101k, BW=393MiB/s (412MB/s)(23.0GiB/60001msec)
    clat (nsec): min=1192, max=2055.0k, avg=115388.32, stdev=55384.50
     lat (nsec): min=1242, max=2055.7k, avg=115786.01, stdev=55442.73
     |  1.00th=[    7],  5.00th=[   11], 10.00th=[   16], 20.00th=[   91],
     | 30.00th=[  100], 40.00th=[  109], 50.00th=[  122], 60.00th=[  137],
     | 70.00th=[  149], 80.00th=[  157], 90.00th=[  167], 95.00th=[  176],
     | 99.00th=[  212], 99.50th=[  273], 99.90th=[  523], 99.95th=[  635],
     | 99.99th=[  914]
   bw (  KiB/s): min=310696, max=581146, per=100.00%, avg=402954.42, stdev=5978.06, samples=1416
   iops        : min=77670, max=145283, avg=100734.63, stdev=1494.51, samples=1416
  lat (usec)   : 2=0.01%, 4=0.06%, 10=4.10%, 20=8.52%, 50=2.18%
  lat (usec)   : 100=15.06%, 250=69.46%, 500=0.50%, 750=0.09%, 1000=0.02%
  cpu          : usr=4.09%, sys=95.88%, ctx=14638, majf=0, minf=12
     issued rwts: total=6038347,0,0,0 short=0,0,0,0 dropped=0,0,0,0
   READ: bw=393MiB/s (412MB/s), 393MiB/s-393MiB/s (412MB/s-412MB/s), io=23.0GiB (24.7GB), run=60001-60001msec
