saikee
 - Feb 7, 2017
I have run a satisfactory service from my FreeNAS 9.10.2-U6 with just one volume for several years.  Now I need to have another volume to store only the photos and music. The second volume has been set up and the files have been copied.  My main application is the Plex Plugin using one jail of Plexmediaserver_1.
I am seeking advice for the following:
(1) Can one use one jail to access two datasets each from a separate volume?
I can add a new jail to point to the second volume as source but its destination always go back to the first volume. There is a configuration option for me to select the jail root but that appears applicable to all the jails. Thus it does not seem possible to have one jail picking files from two volumes. Is this true?
(2) Can one install multiple Plex Plugins using one plugin for one volume?
I need advice on this route as I cannot afford to have the original Plexmediaserver overwritten.
Thanks for your help and any advicee to overcome the above.
System hardware ASUS Prime X399A Ryzen 1900 64GB Ram Boot drive 2x64GB USB 1st Vol 5x8TB HDD Seagate Ironwolf, RAIDZ1 2nd Vol 5x1TB SSD KingSpec, RAIDZ1 Onboard AMD X399 chip set Sata III controller (6 ports)+one generic Sata III controller (6 ports)+one generic Sata III controller (4 ports) IntelEthernet controller I211-AT
