Is GUI SSL Certificate:freenas_default OK?
DavidinGA
I'm confused by references to "wildcard" and the various other conversations about SSL certificates.​
(I did a bunch of searches and read a bunch of stuff and remain confused.)
In the GUI Settings for TrueNAS Scale it shows this ...​
Should I not be concerned, it's fine, or do I need to do something to install a Let's Encrypt certificate?
Thanks ... from a newbie ...
If you're asking the question, I'd say the answer is "no." Is there a particular reason you think you might need one?
DavidinGA
I showed it to someone and he suggested that I did. If it's all good I'm happy to have one less thing to fuss with. I'm still trying to figure out some features of Pico CMS in nextcloud ... Thanks!
