ipmi0 failure - do i even care?
Nerdlinger
Well, i have my first freenas set up. Right now, all I have is the server and a usb key. I do not yet have any disks or zpools. those should be arriving shortly.
It all works well. so far
Last night I actually received my first email alert (Yay, SNMP works)
Unfortunately, i have no idea what the error means, or if I care. Could someone explain the error message?
freenas.home kernel log messages:
> ipmi0: KCS: Read failed on byte 2
> ipmi0: KCS error: 01
-- End of security output --
Nerdlinger
I see. i updated the bios. I didn't realize that ipmi has another prom-y flash-y thing i have to update. i will try that this evening...
melloa
Nerdlinger
you mean a second USB key in mirror? That is definitely on my list. um. how do I mirror them? instructiosn anywhere?
Nerdlinger
melloa
Yes, a 2nd USB key and, yes, above instructions will get you going.
Nerdlinger
Yup. 2 usbs now.flashing the ipmi seems to have done the trick. I never knew there would be so many things to flash...
