IPMI not installed with build 9.2
ric
I have successfully updated my freenas build from 9.1 to 9.2 but the IPMI tab doesn't appear to have on freenas GUI. Some people seems to have success installing without any problem.
Please help.
Yatti420
ric
I followed the above instructions, IPMI successfully installed under Network Settings. Now I can see IPMI tab in freenas GUI, I gave my new password and hit OK, "IPMI failed" pops up.
What should I do to fix this problem?
Your input would greatly appreciated.
Go to the command line.. cat /var/log/messages.
ric
Mar 31 16:00:00 freenas newsyslog[44689]: logfile turned over due to size>100K
Mar 31 16:01:57 freenas smbd[44761]: [2014/03/31 16:01:57.693211, 0] ../source3
/lib/util_sock.c:941(matchname)
Mar 31 16:01:57 freenas smbd[44761]: matchname: host name/name mismatch: 192.1
68.1.114 != (NULL)
Mar 31 16:01:57 freenas smbd[44761]: [2014/03/31 16:01:57.705408, 0] ../source3
/lib/util_sock.c:1199(get_remote_hostname)
Mar 31 16:01:57 freenas smbd[44761]: matchname failed on 192.168.1.114
Mar 31 16:04:59 freenas smbd[44863]: [2014/03/31 16:04:59.113539, 0] ../source3
Mar 31 16:04:59 freenas smbd[44863]: matchname: host name/name mismatch: 192.1
68.1.114 != (NULL)
Mar 31 16:04:59 freenas smbd[44863]: [2014/03/31 16:04:59.113629, 0] ../source3
Mar 31 16:04:59 freenas smbd[44863]: matchname failed on 192.168.1.114
Mar 31 16:07:57 freenas smbd[44890]: [2014/03/31 16:07:57.614150, 0] ../source3
Mar 31 16:07:57 freenas smbd[44890]: matchname: host name/name mismatch: 192.1
68.1.114 != (NULL)
Mar 31 16:07:57 freenas smbd[44890]: [2014/03/31 16:07:57.650307, 0] ../source3
Mar 31 16:07:57 freenas smbd[44890]: matchname failed on 192.168.1.114
Mar 31 16:10:59 freenas smbd[45003]: [2014/03/31 16:10:59.158259, 0] ../source3
Mar 31 16:10:59 freenas smbd[45003]: matchname: host name/name mismatch: 192.1
68.1.114 != (NULL)
Mar 31 16:10:59 freenas smbd[45003]: [2014/03/31 16:10:59.170689, 0] ../source3
Mar 31 16:10:59 freenas smbd[45003]: matchname failed on 192.168.1.114
Mar 31 16:13:57 freenas smbd[45124]: [2014/03/31 16:13:57.662342, 0] ../source3
Mar 31 16:13:57 freenas smbd[45124]: matchname: host name/name mismatch: 192.1
68.1.114 != (NULL)
Mar 31 16:13:57 freenas smbd[45124]: [2014/03/31 16:13:57.662450, 0] ../source3
Mar 31 16:13:57 freenas smbd[45124]: matchname failed on 192.168.1.114
Mar 31 16:16:59 freenas smbd[45162]: [2014/03/31 16:16:59.077518, 0] ../source3
Mar 31 16:16:59 freenas smbd[45162]: matchname: host name/name mismatch: 192.1
68.1.114 != (NULL)
Mar 31 16:16:59 freenas smbd[45162]: [2014/03/31 16:16:59.095133, 0] ../source3
Mar 31 16:16:59 freenas smbd[45162]: matchname failed on 192.168.1.114
Mar 31 19:48:02 freenas manage.py: [freeadmin.navtree:526] Couldn't retrieve htt
p://192.168.1.133/plugins/plexmediaserver/2/_s/treemenu: timed out
[root@freenas ~]#
D
dlavigne
Guest
Is the IPMI device getting it's IP address using DHCP or did you assign it a static IP?
What IP address is the IPMI using?
ric
It was assigned by the DHCP.
I think it's 192.168.1.14(x) .
Yatti420
Regardless (dhcp or static) it fails for me.. Nothing in logs.. There was initially I believe on 9.2.1.. Before upgrades to 9.2.1.x (looks like errors are silenced?)
D
dlavigne
Guest
Were you able to sort this? If not, do you know if a bug report has been made yet?
Yatti420
I've been unable to get the IPMI - FreeNAS intergration working.. Normal IPMI (access supermicro page via IP/Username etc) working fine.. Nothing in logs anymore..
D
dlavigne
Guest
Can you create a bug report then and post the issue number here. This is a new feature and it is quite possible something is missing in it.
Yatti420
D
dlavigne
Guest
I'll mark it as unscreened so it goes back in the queue. Can you provide the info asked for in comment #5?
raidflex
I have the same problem also.
