Kris Heslop
- Feb 7, 2016
Background: IIRC I started getting these error codes under version 9.3, so I upgraded to 11.2 and have continued to update under the stable train.
Current version is 11.2-U5, and I am still getting these DDNS error codes. I have posted a few times in the past on some other threads, but they have not been active and no answers came forward. The problem is likely over 9-months old.
Along the way I have replaced my boot drive, changed the DNS settings from 192.168.2.x to 192.168.6.X. Removed the prior legacy jails.
Deleted all but two of my shares, and installed a new Z1 4x4TB pool, going from a 3x4TB Z1. (Still have a legacy 3TB single drive with the two legacy shares that generally work.)
I updated the DNS servers to use the subnet router (which has listed OpenDNS server cited) @ 192.168.6.1, recently I added the gateway router 192.168.0.1, and Cloudfire's DNS as third 1.1.1.1 although the erro codes have not changed. (The problems started prior to using a subnet, and with a prior router as well.)
I am only uising the Intel Pro add-on NIC, not the on-board NIC that is part of the TS-140.
The FreeNAS box has a dedicated static IP with the router and reserved in the router that is outside the routers DHCP address auto assign range.
Earlier Plex stopped working on the legacy Jail then would run but not broadcast to my Roku or allow any connections-only respond to pings and showed in the windows machine network listing, so as part of redoing the pool from a 3x4TB Z1 to 4x4TB Z1, I replaced updated the jail/plugin to iocages.
On another note, earlier in the week, in the middle of a 300+ GB file transfer to the new pool, I lost SAMBA permissions on my windows machine, but not my Mac. In an effort to continue with the windows transfers (since the Windows machine transfers at 90-120 MB/S or bettter and also does not go through the network when transferring between pools, versus 5-40 MB/s on Mac) I attempted to setup new SMB shares. As I did this, the windows machine would not let me connect, but they showed up in my Mac. In addition I also had two additional shares show up, one with a name I haver used ("homes") and one that I stppped using when I deleted the old pool "Plex2" The permissions dropping off, not responding to changes in system permissions, and then belatedly resetting (this time after about 8 reboots) has occured many times in the past, and predates these error codes and this version of FreeNAS, although in the past it was the Mac that lost permission and the Windows machine would still work.
Since the new shares were not working, I deleted them and noticed it generated the same error codes again. I rebooted and below are the results, the error codes occur at the very end. The random shares that don't exist did go away after deleting the other shares and rebooting.
I have searched these forums, Reddit, and others over the months, and while I find many posts with teh problem, I have not found any posts that share a resolution that has worked for my machine.
My Jails are on a WD Red 3TB drive, the boot disk also hosts the System Dataset, which I recall transferring off of the 3TB drive dataset and some error codes going away, but not these.
Features2=0x7fdafbbf<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,EST,TM2,SSSE3,SDBG,FMA,CX16,xTPR,PDCM,PCID,SSE4.1,SSE4.2,MOVBE,POPCNT,TSCDLT,AESNI,XSAVE,OSXSAVE,AVX,F16C,RDRAND> Jul 20 07:56:00 HeslopNAS AMD Features=0x2c100800<SYSCALL,NX,Page1GB,RDTSCP,LM> Jul 20 07:56:00 HeslopNAS AMD Features2=0x21<LAHF,ABM> Jul 20 07:56:00 HeslopNAS Structured Extended Features=0x27ab<FSGSBASE,TSCADJ,BMI1,AVX2,SMEP,BMI2,ERMS,INVPCID,NFPUSG> Jul 20 07:56:00 HeslopNAS XSAVE Features=0x1<XSAVEOPT> Jul 20 07:56:00 HeslopNAS VT-x: PAT,HLT,MTF,PAUSE,EPT,UG,VPID Jul 20 07:56:00 HeslopNAS TSC: P-state invariant, performance statistics Jul 20 07:56:00 HeslopNAS real memory = 12884901888 (12288 MB) Jul 20 07:56:00 HeslopNAS avail memory = 12210446336 (11644 MB) Jul 20 07:56:00 HeslopNAS Event timer "LAPIC" quality 600 Jul 20 07:56:00 HeslopNAS ACPI APIC Table: <LENOVO TC-FB > Jul 20 07:56:00 HeslopNAS FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs Jul 20 07:56:00 HeslopNAS FreeBSD/SMP: 1 package(s) x 2 core(s) x 2 hardware threads Jul 20 07:56:00 HeslopNAS WARNING: VIMAGE (virtualized network stack) is a highly experimental feature. Jul 20 07:56:00 HeslopNAS ioapic0 <Version 2.0> irqs 0-23 on motherboard Jul 20 07:56:00 HeslopNAS SMP: AP CPU #1 Launched! Jul 20 07:56:00 HeslopNAS SMP: AP CPU #2 Launched! Jul 20 07:56:00 HeslopNAS SMP: AP CPU #3 Launched! Jul 20 07:56:00 HeslopNAS Timecounter "TSC-low" frequency 1696109708 Hz quality 1000 Jul 20 07:56:00 HeslopNAS random: entropy device external interface Jul 20 07:56:00 HeslopNAS random: registering fast source Intel Secure Key RNG Jul 20 07:56:00 HeslopNAS random: fast provider: "Intel Secure Key RNG" Jul 20 07:56:00 HeslopNAS kbd1 at kbdmux0 Jul 20 07:56:00 HeslopNAS nexus0 Jul 20 07:56:00 HeslopNAS vtvga0: <VT VGA driver> on motherboard Jul 20 07:56:00 HeslopNAS cryptosoft0: <software crypto> on motherboard Jul 20 07:56:00 HeslopNAS aesni0: <AES-CBC,AES-XTS,AES-GCM,AES-ICM> on motherboard Jul 20 07:56:00 HeslopNAS padlock0: No ACE support. Jul 20 07:56:00 HeslopNAS acpi0: <LENOVO TC-FB> on motherboard Jul 20 07:56:00 HeslopNAS acpi0: Power Button (fixed) Jul 20 07:56:00 HeslopNAS cpu0: <ACPI CPU> on acpi0 Jul 20 07:56:00 HeslopNAS cpu1: <ACPI CPU> on acpi0 Jul 20 07:56:00 HeslopNAS cpu2: <ACPI CPU> on acpi0 Jul 20 07:56:00 HeslopNAS cpu3: <ACPI CPU> on acpi0 Jul 20 07:56:00 HeslopNAS hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0 Jul 20 07:56:00 HeslopNAS Timecounter "HPET" frequency 14318180 Hz quality 950 Jul 20 07:56:00 HeslopNAS Event timer "HPET" frequency 14318180 Hz quality 550 Jul 20 07:56:00 HeslopNAS Event timer "HPET1" frequency 14318180 Hz quality 440 Jul 20 07:56:00 HeslopNAS Event timer "HPET2" frequency 14318180 Hz quality 440 Jul 20 07:56:00 HeslopNAS Event timer "HPET3" frequency 14318180 Hz quality 440 Jul 20 07:56:00 HeslopNAS Event timer "HPET4" frequency 14318180 Hz quality 440 Jul 20 07:56:00 HeslopNAS atrtc0: <AT realtime clock> port 0x70-0x77 irq 8 on acpi0 Jul 20 07:56:00 HeslopNAS atrtc0: Warning: Couldn't map I/O. Jul 20 07:56:00 HeslopNAS atrtc0: registered as a time-of-day clock, resolution 1.000000s Jul 20 07:56:00 HeslopNAS Event timer "RTC" frequency 32768 Hz quality 0 Jul 20 07:56:00 HeslopNAS attimer0: <AT timer> port 0x40-0x43,0x50-0x53 irq 0 on acpi0 Jul 20 07:56:00 HeslopNAS Timecounter "i8254" frequency 1193182 Hz quality 0 Jul 20 07:56:00 HeslopNAS Event timer "i8254" frequency 1193182 Hz quality 100 Jul 20 07:56:00 HeslopNAS Timecounter "ACPI-fast" frequency 3579545 Hz quality 900 Jul 20 07:56:00 HeslopNAS acpi_timer0: <24-bit timer at 3.579545MHz> port 0x1808-0x180b on acpi0 Jul 20 07:56:00 HeslopNAS pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0 Jul 20 07:56:00 HeslopNAS pcib0: _OSC returned error 0x10 Jul 20 07:56:00 HeslopNAS pci0: <ACPI PCI bus> on pcib0 Jul 20 07:56:00 HeslopNAS vgapci0: <VGA-compatible display> port 0xf000-0xf03f mem 0xf7800000-0xf7bfffff,0xe0000000-0xefffffff irq 16 at device 2.0 on pci0 Jul 20 07:56:00 HeslopNAS vgapci0: Boot video device Jul 20 07:56:00 HeslopNAS pci0: <multimedia, HDA> at device 3.0 (no driver attached) Jul 20 07:56:00 HeslopNAS xhci0: <Intel Lynx Point USB 3.0 controller> mem 0xf7d20000-0xf7d2ffff irq 16 at device 20.0 on pci0 Jul 20 07:56:00 HeslopNAS xhci0: 32 bytes context size, 64-bit DMA Jul 20 07:56:00 HeslopNAS xhci0: Port routing mask set to 0xffffffff Jul 20 07:56:00 HeslopNAS usbus0 on xhci0 Jul 20 07:56:00 HeslopNAS usbus0: 5.0Gbps Super Speed USB v3.0 Jul 20 07:56:00 HeslopNAS pci0: <simple comms> at device 22.0 (no driver attached) Jul 20 07:56:00 HeslopNAS uart2: <Intel Lynx Point KT Controller> port 0xf0e0-0xf0e7 mem 0xf7d3e000-0xf7d3efff irq 19 at device 22.3 on pci0 Jul 20 07:56:00 HeslopNAS em0: <Intel(R) PRO/1000 Network Connection 7.6.1-k> port 0xf080-0xf09f mem 0xf7d00000-0xf7d1ffff,0xf7d3d000-0xf7d3dfff irq 20 at device 25.0 on pci0 Jul 20 07:56:00 HeslopNAS em0: Using an MSI interrupt Jul 20 07:56:00 HeslopNAS em0: Ethernet address: 6c:0b:84:3e:2d:94 Jul 20 07:56:00 HeslopNAS ehci0: <Intel Lynx Point USB 2.0 controller USB-B> mem 0xf7d3c000-0xf7d3c3ff irq 17 at device 26.0 on pci0 Jul 20 07:56:00 HeslopNAS usbus1: EHCI version 1.0 Jul 20 07:56:00 HeslopNAS usbus1 on ehci0 Jul 20 07:56:00 HeslopNAS usbus1: 480Mbps High Speed USB v2.0 Jul 20 07:56:00 HeslopNAS pci0: <multimedia, HDA> at device 27.0 (no driver attached) Jul 20 07:56:00 HeslopNAS pcib1: <ACPI PCI-PCI bridge> irq 16 at device 28.0 on pci0 Jul 20 07:56:00 HeslopNAS pci1: <ACPI PCI bus> on pcib1 Jul 20 07:56:00 HeslopNAS pcib2: <ACPI PCI-PCI bridge> irq 17 at device 28.1 on pci0 Jul 20 07:56:00 HeslopNAS pcib2: [GIANT-LOCKED] Jul 20 07:56:00 HeslopNAS pci2: <ACPI PCI bus> on pcib2 Jul 20 07:56:00 HeslopNAS em1: <Intel(R) PRO/1000 Network Connection 7.6.1-k> port 0xe000-0xe01f mem 0xf7c20000-0xf7c3ffff,0xf7c00000-0xf7c1ffff irq 17 at device 0.0 on pci2 Jul 20 07:56:00 HeslopNAS em1: Using an MSI interrupt Jul 20 07:56:00 HeslopNAS em1: Ethernet address: 00:15:17:f0:68:ae Jul 20 07:56:00 HeslopNAS pcib3: <ACPI PCI-PCI bridge> irq 19 at device 28.3 on pci0 Jul 20 07:56:00 HeslopNAS pci3: <ACPI PCI bus> on pcib3 Jul 20 07:56:00 HeslopNAS pcib4: <ACPI PCI-PCI bridge> irq 19 at device 0.0 on pci3 Jul 20 07:56:00 HeslopNAS pci4: <ACPI PCI bus> on pcib4 Jul 20 07:56:00 HeslopNAS ehci1: <Intel Lynx Point USB 2.0 controller USB-A> mem 0xf7d3b000-0xf7d3b3ff irq 23 at device 29.0 on pci0 Jul 20 07:56:00 HeslopNAS usbus2: EHCI version 1.0 Jul 20 07:56:00 HeslopNAS usbus2 on ehci1 Jul 20 07:56:00 HeslopNAS usbus2: 480Mbps High Speed USB v2.0 Jul 20 07:56:00 HeslopNAS isab0: <PCI-ISA bridge> at device 31.0 on pci0 Jul 20 07:56:00 HeslopNAS isa0: <ISA bus> on isab0 Jul 20 07:56:00 HeslopNAS ahci0: <Intel Lynx Point AHCI SATA controller> port 0xf0d0-0xf0d7,0xf0c0-0xf0c3,0xf0b0-0xf0b7,0xf0a0-0xf0a3,0xf060-0xf07f mem 0xf7d3a000-0xf7d3a7ff irq 19 at device 31.2 on pci0 Jul 20 07:56:00 HeslopNAS ahci0: AHCI v1.30 with 5 6Gbps ports, Port Multiplier not supported Jul 20 07:56:00 HeslopNAS ahcich0: <AHCI channel> at channel 0 on ahci0 Jul 20 07:56:00 HeslopNAS ahcich1: <AHCI channel> at channel 1 on ahci0 Jul 20 07:56:00 HeslopNAS ahcich2: <AHCI channel> at channel 2 on ahci0 Jul 20 07:56:00 HeslopNAS ahcich3: <AHCI channel> at channel 3 on ahci0 Jul 20 07:56:00 HeslopNAS ahcich4: <AHCI channel> at channel 4 on ahci0 Jul 20 07:56:00 HeslopNAS acpi_button0: <Power Button> on acpi0 Jul 20 07:56:00 HeslopNAS acpi_tz0: <Thermal Zone> on acpi0 Jul 20 07:56:00 HeslopNAS acpi_tz1: <Thermal Zone> on acpi0 Jul 20 07:56:00 HeslopNAS uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0 Jul 20 07:56:00 HeslopNAS ichwd0: <Intel Lynx Point watchdog timer> on isa0 Jul 20 07:56:00 HeslopNAS orm0: <ISA Option ROMs> at iomem 0xd0000-0xd0fff,0xd1000-0xd1fff on isa0 Jul 20 07:56:00 HeslopNAS atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0 Jul 20 07:56:00 HeslopNAS atkbd0: <AT Keyboard> irq 1 on atkbdc0 Jul 20 07:56:00 HeslopNAS kbd0 at atkbd0 Jul 20 07:56:00 HeslopNAS atkbd0: [GIANT-LOCKED] Jul 20 07:56:00 HeslopNAS coretemp0: <CPU On-Die Thermal Sensors> on cpu0 Jul 20 07:56:00 HeslopNAS est0: <Enhanced SpeedStep Frequency Control> on cpu0 Jul 20 07:56:00 HeslopNAS coretemp1: <CPU On-Die Thermal Sensors> on cpu1 Jul 20 07:56:00 HeslopNAS est1: <Enhanced SpeedStep Frequency Control> on cpu1 Jul 20 07:56:00 HeslopNAS coretemp2: <CPU On-Die Thermal Sensors> on cpu2 Jul 20 07:56:00 HeslopNAS est2: <Enhanced SpeedStep Frequency Control> on cpu2 Jul 20 07:56:00 HeslopNAS coretemp3: <CPU On-Die Thermal Sensors> on cpu3 Jul 20 07:56:00 HeslopNAS est3: <Enhanced SpeedStep Frequency Control> on cpu3 Jul 20 07:56:00 HeslopNAS ZFS filesystem version: 5 Jul 20 07:56:00 HeslopNAS ZFS storage pool version: features support (5000) Jul 20 07:56:00 HeslopNAS Timecounters tick every 1.000 msec Jul 20 07:56:00 HeslopNAS freenas_sysctl: adding account. Jul 20 07:56:00 HeslopNAS freenas_sysctl: adding directoryservice. Jul 20 07:56:00 HeslopNAS freenas_sysctl: adding middlewared. Jul 20 07:56:00 HeslopNAS freenas_sysctl: adding network. Jul 20 07:56:00 HeslopNAS freenas_sysctl: adding services. Jul 20 07:56:00 HeslopNAS ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled Jul 20 07:56:00 HeslopNAS ugen2.1: <Intel EHCI root HUB> at usbus2 Jul 20 07:56:00 HeslopNAS ugen1.1: <Intel EHCI root HUB> at usbus1 Jul 20 07:56:00 HeslopNAS ugen0.1: <0x8086 XHCI root HUB> at usbus0 Jul 20 07:56:00 HeslopNAS uhub0: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus2 Jul 20 07:56:00 HeslopNAS uhub1: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1 Jul 20 07:56:00 HeslopNAS uhub2: <0x8086 XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0 Jul 20 07:56:00 HeslopNAS uhub2: 21 ports with 21 removable, self powered Jul 20 07:56:00 HeslopNAS uhub1: 3 ports with 3 removable, self powered Jul 20 07:56:00 HeslopNAS uhub0: 3 ports with 3 removable, self powered Jul 20 07:56:00 HeslopNAS ugen0.2: <Logitech USB Receiver> at usbus0 Jul 20 07:56:00 HeslopNAS ukbd0 on uhub2 Jul 20 07:56:00 HeslopNAS ukbd0: <Logitech USB Receiver, class 0/0, rev 2.00/24.00, addr 1> on usbus0 Jul 20 07:56:00 HeslopNAS kbd2 at ukbd0 Jul 20 07:56:00 HeslopNAS ugen1.2: <vendor 0x8087 product 0x8008> at usbus1 Jul 20 07:56:00 HeslopNAS uhub3 on uhub1 Jul 20 07:56:00 HeslopNAS uhub3: <vendor 0x8087 product 0x8008, class 9/0, rev 2.00/0.04, addr 2> on usbus1 Jul 20 07:56:00 HeslopNAS ugen2.2: <vendor 0x8087 product 0x8000> at usbus2 Jul 20 07:56:00 HeslopNAS uhub4 on uhub0 Jul 20 07:56:00 HeslopNAS uhub4: <vendor 0x8087 product 0x8000, class 9/0, rev 2.00/0.04, addr 2> on usbus2 Jul 20 07:56:00 HeslopNAS uhub3: 6 ports with 6 removable, self powered Jul 20 07:56:00 HeslopNAS uhub4: 8 ports with 8 removable, self powered Jul 20 07:56:00 HeslopNAS ugen0.3: <CPS CP1000PFCLCD> at usbus0 Jul 20 07:56:00 HeslopNAS ugen0.4: <SanDisk Ultra Fit> at usbus0 Jul 20 07:56:00 HeslopNAS umass0 on uhub2 Jul 20 07:56:00 HeslopNAS umass0: <SanDisk Ultra Fit, class 0/0, rev 3.00/1.00, addr 3> on usbus0 Jul 20 07:56:00 HeslopNAS umass0: SCSI over Bulk-Only; quirks = 0xc100 Jul 20 07:56:00 HeslopNAS umass0:6:0: Attached to scbus6 Jul 20 07:56:00 HeslopNAS ada0 at ahcich0 bus 0 scbus0 target 0 lun 0 Jul 20 07:56:00 HeslopNAS ada0: <WDC WD30EFRX-68EUZN0 82.00A82> ACS-2 ATA SATA 3.x device Jul 20 07:56:00 HeslopNAS ada0: Serial Number WD-WCC4N1JPZ1NS Jul 20 07:56:00 HeslopNAS ada0: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes) Jul 20 07:56:00 HeslopNAS ada0: Command Queueing enabled Jul 20 07:56:00 HeslopNAS ada0: 2861588MB (5860533168 512 byte sectors) Jul 20 07:56:00 HeslopNAS ada0: quirks=0x1<4K> Jul 20 07:56:00 HeslopNAS ada1 at ahcich1 bus 0 scbus1 target 0 lun 0 Jul 20 07:56:00 HeslopNAS ada1: <WDC WD40EFRX-68WT0N0 82.00A82> ACS-2 ATA SATA 3.x device Jul 20 07:56:00 HeslopNAS ada1: Serial Number WD-WCC4E7EF2ES3 Jul 20 07:56:00 HeslopNAS ada1: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes) Jul 20 07:56:00 HeslopNAS ada1: Command Queueing enabled Jul 20 07:56:00 HeslopNAS ada1: 3815447MB (7814037168 512 byte sectors) Jul 20 07:56:00 HeslopNAS ada1: quirks=0x1<4K> Jul 20 07:56:00 HeslopNAS ada2 at ahcich2 bus 0 scbus2 target 0 lun 0 Jul 20 07:56:00 HeslopNAS ada2: <WDC WD40EFRX-68N32N0 82.00A82> ACS-3 ATA SATA 3.x device Jul 20 07:56:00 HeslopNAS ada2: Serial Number WD-WCC7K6NCJ820 Jul 20 07:56:00 HeslopNAS ada2: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes) Jul 20 07:56:00 HeslopNAS ada2: Command Queueing enabled Jul 20 07:56:00 HeslopNAS ada2: 3815447MB (7814037168 512 byte sectors) Jul 20 07:56:00 HeslopNAS ada2: quirks=0x1<4K> Jul 20 07:56:00 HeslopNAS ada3 at ahcich3 bus 0 scbus3 target 0 lun 0 Jul 20 07:56:00 HeslopNAS ada3: <HGST HDN724040ALE640 MJAOA5E0> ATA8-ACS SATA 3.x device Jul 20 07:56:00 HeslopNAS ada3: Serial Number PK1334PEKDT7RS Jul 20 07:56:00 HeslopNAS ada3: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes) Jul 20 07:56:00 HeslopNAS ada3: Command Queueing enabled Jul 20 07:56:00 HeslopNAS ada3: 3815447MB (7814037168 512 byte sectors) Jul 20 07:56:00 HeslopNAS ada4 at ahcich4 bus 0 scbus4 target 0 lun 0 Jul 20 07:56:00 HeslopNAS ada4: <WDC WD40EFRX-68WT0N0 82.00A82> ACS-2 ATA SATA 3.x device Jul 20 07:56:00 HeslopNAS ada4: Serial Number WD-WCC4E6LE20KY Jul 20 07:56:00 HeslopNAS ada4: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 8192bytes) Jul 20 07:56:00 HeslopNAS ada4: Command Queueing enabled Jul 20 07:56:00 HeslopNAS ada4: 3815447MB (7814037168 512 byte sectors) Jul 20 07:56:00 HeslopNAS ada4: quirks=0x1<4K> Jul 20 07:56:00 HeslopNAS da0 at umass-sim0 bus 0 scbus6 target 0 lun 0 Jul 20 07:56:00 HeslopNAS da0: <SanDisk Ultra Fit 1.00> Removable Direct Access SPC-4 SCSI device Jul 20 07:56:00 HeslopNAS da0: Serial Number 4C530000231017101345 Jul 20 07:56:00 HeslopNAS da0: 400.000MB/s transfers Jul 20 07:56:00 HeslopNAS da0: 14664MB (30031872 512 byte sectors) Jul 20 07:56:00 HeslopNAS da0: quirks=0x2<NO_6_BYTE> Jul 20 07:56:00 HeslopNAS random: unblocking device. Jul 20 07:56:00 HeslopNAS Trying to mount root from zfs:freenas-boot/ROOT/11.2-U5 []... Jul 20 07:56:00 HeslopNAS kernel: em1: link state changed to UP Jul 20 07:56:00 HeslopNAS kernel: em1: link state changed to UP Jul 20 07:56:00 HeslopNAS GEOM_MIRROR: Device mirror/swap0 launched (2/2). Jul 20 07:56:00 HeslopNAS GEOM_MIRROR: Device mirror/swap1 launched (2/2). Jul 20 07:56:00 HeslopNAS GEOM_ELI: Device mirror/swap0.eli created. Jul 20 07:56:00 HeslopNAS GEOM_ELI: Encryption: AES-XTS 128 Jul 20 07:56:00 HeslopNAS GEOM_ELI: Crypto: hardware Jul 20 07:56:00 HeslopNAS GEOM_ELI: Device mirror/swap1.eli created. Jul 20 07:56:00 HeslopNAS GEOM_ELI: Encryption: AES-XTS 128 Jul 20 07:56:00 HeslopNAS GEOM_ELI: Crypto: hardware Jul 20 07:56:00 HeslopNAS hwpmc: SOFT/16/64/0x67<INT,USR,SYS,REA,WRI> TSC/1/64/0x20<REA> IAP/4/48/0x3ff<INT,USR,SYS,EDG,THR,REA,WRI,INV,QUA,PRC> IAF/3/48/0x67<INT,USR,SYS,REA,WRI> UCP/8/48/0x3f8<EDG,THR,REA,WRI,INV,QUA,PRC> UCF/1/48/0x60<REA,WRI> Jul 20 07:56:00 HeslopNAS kernel: em1: link state changed to DOWN Jul 20 07:56:00 HeslopNAS kernel: em1: link state changed to DOWN Jul 20 07:56:00 HeslopNAS kernel: em1: link state changed to UP Jul 20 07:56:00 HeslopNAS kernel: em1: link state changed to UP Jul 20 07:56:00 HeslopNAS ums0 on uhub2 Jul 20 07:56:00 HeslopNAS ums0: <Logitech USB Receiver, class 0/0, rev 2.00/24.00, addr 1> on usbus0 Jul 20 07:56:00 HeslopNAS ums0: 16 buttons and [XYZT] coordinates ID=2 Jul 20 07:56:00 HeslopNAS uhid0 on uhub2 Jul 20 07:56:00 HeslopNAS uhid0: <Logitech USB Receiver, class 0/0, rev 2.00/24.00, addr 1> on usbus0 Jul 20 07:56:01 HeslopNAS ntpd[2992]: ntpd 4.2.8p11-a (1): Starting Jul 20 07:56:10 HeslopNAS bridge0: Ethernet address: 02:a8:af:44:86:00 Jul 20 07:56:10 HeslopNAS epair0a: Ethernet address: 02:5e:d0:00:05:0a Jul 20 07:56:10 HeslopNAS epair0b: Ethernet address: 02:5e:d0:00:06:0b Jul 20 07:56:10 HeslopNAS kernel: epair0a: link state changed to UP Jul 20 07:56:10 HeslopNAS kernel: epair0a: link state changed to UP Jul 20 07:56:10 HeslopNAS kernel: epair0b: link state changed to UP Jul 20 07:56:10 HeslopNAS kernel: epair0b: link state changed to UP Jul 20 07:56:10 HeslopNAS kernel: epair0a: changing name to 'vnet0:1' Jul 20 07:56:10 HeslopNAS kernel: em1: promiscuous mode enabled Jul 20 07:56:10 HeslopNAS kernel: bridge0: link state changed to UP Jul 20 07:56:10 HeslopNAS kernel: bridge0: link state changed to UP Jul 20 07:56:10 HeslopNAS kernel: em1: link state changed to DOWN Jul 20 07:56:10 HeslopNAS kernel: em1: link state changed to DOWN Jul 20 07:56:10 HeslopNAS kernel: vnet0:1: promiscuous mode enabled Jul 20 07:56:13 HeslopNAS kernel: em1: link state changed to UP Jul 20 07:56:13 HeslopNAS kernel: em1: link state changed to UP Jul 20 07:56:35 HeslopNAS dhclient: New IP Address (em1): 192.168.6.3 Jul 20 13:56:35 HeslopNAS /middlewared[240]: dnssd_clientstub DNSServiceRefSockFD called with invalid DNSServiceRef 0x81bc446a0 FFFFFFFF DDDDDDDD Jul 20 07:56:35 HeslopNAS dhclient: New Subnet Mask (em1): 255.255.255.0 Jul 20 13:56:35 HeslopNAS /middlewared[240]: dnssd_clientstub DNSServiceRefSockFD called with invalid DNSServiceRef 0x81bc445e0 FFFFFFFF DDDDDDDD Jul 20 13:56:35 HeslopNAS /middlewared[240]: dnssd_clientstub DNSServiceRefSockFD called with invalid DNSServiceRef 0x81bc44b80 FFFFFFFF DDDDDDDD Jul 20 07:56:35 HeslopNAS dhclient: New Broadcast Address (em1): 192.168.6.255 Jul 20 13:56:35 HeslopNAS /middlewared[240]: dnssd_clientstub DNSServiceProcessResult called with invalid DNSServiceRef 0x81bc446a0 FFFFFFFF DDDDDDDD Jul 20 07:56:35 HeslopNAS dhclient: New Routers (em1): 192.168.6.1
