SweetAndLow
Sweet'NASty
- Nov 6, 2013
I gave you a link that describes how I set things up. Lacp with unifi switch. Did you follow those steps? If you can't see the interface when setting up the lacp then you need to create the interface first before you can add it to the lacp group. I suggest only using the console since doing this will cause the web gui to drop out unless you have a dedicated management interface.Bump
