Intel xxv710 NIC not showing
Flupp
I just installed the latest version of CORE and the my intel xxv710da2 nic isn't showing up at all. The onboard interfaces are showing as expected but I can't see the NIC. I've read that this specific card should be supported just fine and freebsd does seem to support it with the ixl drivers but I can't find these on my truenas core setup?
ifconfig doesn't show the interfaces at all
I run some of those without issue:
ixl0: flags=8863<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
    options=8100b8<VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWFILTER>
    ether 40:xx:xx:xx:xx:xx
    media: Ethernet autoselect
    status: no carrier
ixl1: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
    media: Ethernet autoselect (10Gbase-SR <full-duplex>)
    status: active
Are you sure your card has the yottamark?
Flupp
It "should" be a genuine card, I got this 2U server configured from SCAN, one of the largest system integrators / retailers in the UK.
I also tried Scale and the same problem. I'm half tempted to throw regular old windows on there to see if it gets picked up at all. I can see it on the switch side and the link is up though...
Flupp
I also can't see the kernel driver being loaded when looking at lspci -nn -k , besides the onboard drivers.
