Intel C608 SAS controller
Racinrandall
<div class="bbWrapper">I recently built a new system using at Tyan dual Socket 2011 motherboard using the Intel Patsburg chipset. <br /> When I run the lspci command from the shell it sees the Intel C608 dual SAS controller. However the drives that are connected to it do not show up when I try to build a pool.<br /> <br /> I have verified the controller can see the drives. I'm guessing it is a driver issue. I found some info on FreeBSD and the use of the isci driver to support that controller. It wasn't real helpful on how to load this driver though and I'm not very well versed in how to do such things on BSD.<br /> <br /> Any help would be greatly appreciated.</div>
D
dlavigne
Guest
<div class="bbWrapper">It's worthwhile to create a bug report at bugs.freenas.org that includes a debug (created in System -&gt; Advanced -&gt; Save Debug) and post the issue number here. That way a dev can determine if the driver is missing or if there is a bug in the driver.</div>
mav@
<div class="bbWrapper">FreeNAS kernel by default includes the isci driver. It should not require any more setup actions. So we need more information to debug this, as Dru have told.</div>
Racinrandall
<div class="bbWrapper">Here is the bug report #13663<br /> <a href="https://bugs.freenas.org/issues/13663" target="_blank" class="link link--external" rel="nofollow ugc noopener">https://bugs.freenas.org/issues/13663</a></div>
