Installing Ubiquiti UniFi Controller in a jail
AVSION
Hi m0nkey_ just checked unifi5 via pkg version is 5.7.23 vs ports 5.8.24 can i upgrade pkg after install to the latest version or we have to wait when available? also any difference or prones /cones in terms of functionality and features between the pkg and ports except pkg is easy to install?
thank you
BoXstA
Hi, I just recently updated my Unifi controller running in a jail on FreeNAS 11.1-U6, everything went smoothly however I'm stuck on the UniFi SDN - Server Status page with "UniFi Controller is starting up...".
This has been stuck for about an hour and the server was rebooted following the update. Any suggestions?
server.log shows
<db-server> ERROR system - [exec] error, rc=141, cmdline=[bin/mongod, --dbpath, /usr/local/share/java/unif
i/data/db, --port, 27117, --unixSocketPrefix, /usr/local/share/java/unifi/run, --logappend, --logpath, /usr/local/share/java/unifi/l
ogs/mongod.log, --nohttpinterface, --bind_ip, 127.0.0.1]
Jailer
Not strong, but bad
server.log shows
Same here. Just updated and I'm stuck with the same situation.
Jailer
Not strong, but bad
No I just shut it off for the time being.
gt2416
The problem is that MongoDB is compiled for 11.2 and requires libdl.so and libdl.so.1.
You can install 11.2 in a vm and copy the files from the VM's 11.2 /usr/lib to the 11.1 jails /usr/lib. (Or pm me, Ill gladly share it).
You can confirm this is your issue by typing mongod in your jail shell. Mongo will fail to start and tell you those files are missing. I have the latest unifi running on 11.1-U6 with just pkg install unifi5 and those files I mentioned.
Happy Thanksgiving guys :)
NasKar
It's amazing how much aggravation 11.1 not being supported is causing. Thanks for the tip, mine is working now.
colmconn
I used the following workarounds to get it to install on a 11.1 jail on 11.1-U6. Hope it helps.
After jail creation (fix for installing s/w on 11.1 based on https://forums.freenas.org/index.ph...-with-libdl-so-1-not-found-error.70391/page-2)
  1. Edit /etc/pkg/FreeBSD.conf
    1. Replace quarterly with release_2 (it was the last release without the libdl library
  2. Edit /usr/local/etc/pkg.conf
    1. Add set OSVERSION = 1101001 as the first line
  3. pkg update
  4. Install packages listed here https://github.com/kjake/freenas-iocage-unifi/blob/master/unifi-jail.sh except
    1. Replace mongodb with mongodb34
    2. pkg install -y openjdk8 python mongodb34 bash snappyjava gmake gettext indexinfo zip git dehydrated py27-pip
    3. portsnap fetch extract
    4. env ALLOW_UNSUPPORTED_SYSTEM=YES make -C /usr/ports/net-mgmt/unifi5 clean install BATCH=yes
  5. Start mongodb
    1. sysrc mongod_enable=YES
    2. service mongod start
      1. By default this makes it listen on 127.0.0.1 and any one in the jail can connect to it
    3. Start unifi
      1. sysrc unifi_enable=YES
      2. service unifi start
    4. Connect to unifi in browser at https://${JAIL_IP}:8443/
Jailer
Not strong, but bad
I have libdl.so.1 but not libdl.so in a fresh FreeBSD 11.2 installation. If you could send them to me that would be great.
EDIT: Disregard. I added just libdl.so.1 and it started up.
swil00
Hi, I'm running FREENAS 11.2-RC1 currently with UniFi 5.8.24 in an iocage jail.
Over the past few days I've been trying to upgrade to the latest 5.9.29, however keep hitting errors, which I think are caused by mongodb versions.
What's the best workaround for this ?
I've trying make package, bit it still fails... see attachment.
Any advise and help would be greatly appreciated.
Jailer
Not strong, but bad
Did you even read this thread? The answer posted just a few replies before yours.
ChrisChros
Hi guys,
one question, how can I install the Unifi Controller in an iocage?
I have installed FreeNAS 11.2 RC2 and I can creat a jail but when I want to execute the following command in the shell "jexec <jailname> csh" I just receive an error message. Of course I changed "<jailname>" with the right name.
Is the "jexec" command the right one for a the iocage?
swil00
Why thanks. Yes, I did read this thread, but it would seem my issue was a little different to others.
I should have pointed out that my iocage was built using 11.2, so in order to resolve my issue, I took a backup of my config, removed mongodb34-3.x.xx package and ran make install again. Worked this time not having the conflict of different mongodb versions.
I'm now running 5.9.29
swil00
Hi guys,
If you have already created the jail using iocage, then instead of running "jexec <jailname> csh", try "iocage exec <jailname> csh"
The steps in this guide are the same after this.
ChrisChros
Thanks for the answer, will try it later.
UPDATE:
its working. Thanks for your help.
thejamesk
Hi
Great guide and thanks for providing it @m0nkey_ !
Unfortunately after following the video twice I still get an error when trying to start the service. Can anyone help? :)
Dayve
Hey Guys,
Thanks for the great instructions. Got everything working and transferred my Unifi setup from my Raspberry pie over to FreeNAS :)
The only thing that will not work is starting the jail on boot.
I did the "sysrc unifi_enable=YES" command and also checked the rc.conf file for enable. Not sure what I missed.
ifconfig_epair0b="DHCP"
host_hostname="Unifi Controller"
cron_flags="$cron_flags -J 15"
# Disable Sendmail by default
sendmail_enable="NONE"
sendmail_submit_enable="NO"
sendmail_outbound_enable="NO"
sendmail_msp_queue_enable="NO"
# Run secure syslog
syslogd_flags="-c -ss"
# Enable IPv6
ipv6_activate_all_interfaces="YES"
# Enable at Boot
unifi_enable="YES"
SweetAndLow
Sweet'NASty
Hey Guys,
# Run secure syslog
# Enable IPv6
# Enable at Boot
unifi_enable="YES"
You check the box to start the jail on boot in the freenas UI?
