sensor76140
- Oct 25, 2014
ça répond bien au ping
root@pyload:/ # pyload
06.06.2015 19:45:36 INFO Démarrage pyLoad 0.4.9
06.06.2015 19:45:36 INFO Utilisation du dossier principal : /root/pyload
File "/usr/local/bin/pyload", line 668, in <module>
main()
File "/usr/local/bin/pyload", line 659, in main
pyload_core.start()
File "/usr/local/bin/pyload", line 393, in start
self.pluginManager = PluginManager(self)
File "/usr/local/share/pyload/module/plugins/PluginManager.py", line 50, in __init__
self.createIndex()
File "/usr/local/share/pyload/module/plugins/PluginManager.py", line 73, in createIndex
self.plugins["hooks"] = self.hookPlugins = self.parse("hooks")
File "/usr/local/share/pyload/module/plugins/PluginManager.py", line 196, in parse
temp = self.parse(folder, pattern, plugins)
File "/usr/local/share/pyload/module/plugins/PluginManager.py", line 163, in parse
config = literal_eval(config[0].strip().replace("\n", "").replace("\r", ""))
File "/usr/local/share/pyload/module/lib/SafeEval.py", line 45, in const_eval
return eval(c, None, _locals)
File "", line 1, in <module>
TypeError: bad operand type for unary +: 'tuple'
root@pyload:/ #
root@pyload:/ # pkg -vv
Version                 : 1.5.3
PKG_DBDIR = "/var/db/pkg";
PKG_CACHEDIR = "/var/cache/pkg";
PORTSDIR = "/usr/ports";
INDEXDIR = "";
INDEXFILE = "INDEX-9";
HANDLE_RC_SCRIPTS = false;
DEFAULT_ALWAYS_YES = false;
ASSUME_ALWAYS_YES = false;
REPOS_DIR [
    "/etc/pkg/",
    "/usr/local/etc/pkg/repos/",
PLIST_KEYWORDS_DIR = "";
SYSLOG = true;
ABI = "FreeBSD:9:amd64";
ALTABI = "freebsd:9:x86:64";
DEVELOPER_MODE = false;
VULNXML_SITE = "http://vuxml.freebsd.org/freebsd/vuln.xml.bz2";
FETCH_RETRY = 3;
PKG_PLUGINS_DIR = "/usr/local/lib/pkg/";
PKG_ENABLE_PLUGINS = true;
PLUGINS [
DEBUG_SCRIPTS = false;
PLUGINS_CONF_DIR = "/usr/local/etc/pkg/";
PERMISSIVE = false;
REPO_AUTOUPDATE = true;
NAMESERVER = "";
EVENT_PIPE = "";
FETCH_TIMEOUT = 30;
UNSET_TIMESTAMP = false;
SSH_RESTRICT_DIR = "";
PKG_ENV {
PKG_SSH_ARGS = "";
DEBUG_LEVEL = 0;
ALIAS {
    all-depends = "query %dn-%dv";
    annotations = "info -A";
    build-depends = "info -qd";
    cinfo = "info -Cx";
    comment = "query -i \"%c\"";
    csearch = "search -Cx";
    desc = "query -i \"%e\"";
    download = "fetch";
    iinfo = "info -ix";
    isearch = "search -ix";
    prime-list = "query -e '%a = 0' '%n'";
    leaf = "query -e '%#r == 0' '%n-%v'";
    list = "info -ql";
    noauto = "query -e '%a == 0' '%n-%v'";
    options = "query -i \"%n - %Ok: %Ov\"";
    origin = "info -qo";
    provided-depends = "info -qb";
    raw = "info -R";
    required-depends = "info -qr";
    roptions = "rquery -i \"%n - %Ok: %Ov\"";
    shared-depends = "info -qB";
    show = "info -f -k";
    size = "info -sq";
CUDF_SOLVER = "";
SAT_SOLVER = "";
RUN_SCRIPTS = true;
CASE_SENSITIVE_MATCH = false;
LOCK_WAIT = 1;
LOCK_RETRIES = 5;
SQLITE_PROFILE = false;
WORKERS_COUNT = 0;
READ_LOCK = false;
PLIST_ACCEPT_DIRECTORIES = false;
IP_VERSION = 0;
AUTOMERGE = true;
VERSION_SOURCE = "";
CONSERVATIVE_UPGRADE = true;
PKG_CREATE_VERBOSE = false;
Repositories:
  FreeBSD: {
    url             : "pkg+http://pkg.FreeBSD.org/freebsd:9:x86:64/latest",
    enabled         : yes,
    priority        : 0,
    mirror_type     : "SRV"
root@pyload:/ # pkg search git abbayedesmorts-git20150512 bzr-git-0.6.8_1 cgit-0.11.2 digitalcoin-1.0.0.0b_3 digitemp-3.6.0 easygit-0.98 git-2.4.2 git-bzr-ng-git20140423 git-extras-3.0.0 git-lite-2.4.2 git-merge-changelog-20140202 git-modes-emacs24-20150317_1 git-review-1.24_1 git-subversion-2.4.2 gitflow-1.8.0 gitg-3.16.1 gitg0-0.0.8_1 github-backup-utils-2.2.0 gitinspector-0.3.2 gitolite-3.6.1_1,1 gitolite2-2.3.1_1 gitphp-0.2.8_1 gittrac-2.0.1_1 griels-quest-git20150512 gtk-digital-cream-theme-1.0_8 gtk-digital-harmony-theme-1.1_8 hs-git-annex-5.20140817_1 hs-gitit-0.10.6.1_1 libgit2-0.22.2 libgit2-glib-0.22.8 libvterm-git20150527 magit-emacs24-1.4.0_1 metacity-digital-cream-theme-1.0_8 metacity-digital-harmony-theme-1.1_8 osmium-git20130522_9 p5-Algorithm-CheckDigits-1.3.0_1 p5-App-GitGot-1.33 p5-App-GitHub-1.0.1_1 p5-Config-GitLike-1.16 p5-Git-PurePerl-0.51 p5-Git-Repository-1.314 p5-Git-Repository-Plugin-Log-1.312_1 p5-Git-Sub-0.130270_1 p5-Git-Wrapper-0.044 p5-GitDDL-0.03 p5-GitDDL-Migrator-0.07 p5-Net-GitHub-0.75 p5-WWW-GitHub-Gist-0.17_1 p5-github_creator-0.15_1 pear-SebastianBergmann_Git-1.2.0 pear-VersionControl_Git-0.4.4 py27-django-taggit-0.12.1 py27-git-up-1.2.2 py27-gitdb-0.6.4_1 py27-gitosis-0.2.20090917_1 py27-hg-git-0.8.1 py27-pygit2-0.22.0 py27-pygithub-1.25.0 py27-python-digitalocean-1.3 py27-setuptools-git-1.1 py27-wsgitools-0.3 qgit-qt4-2.3_1 rubygem-gemnasium-gitlab-service-0.2.6 rubygem-git-1.2.9.1 rubygem-github-linguist-4.5.2 rubygem-github-markdown-0.6.8 rubygem-github-markup-1.3.3 rubygem-github_api-0.12.3 rubygem-gitlab-flowdock-git-hook-0.4.2.2 rubygem-gitlab-gollum-lib-1.1.0_3 rubygem-gitlab-grack-2.0.2_1 rubygem-gitlab-grit-2.7.3_1 rubygem-gitlab-linguist-3.0.1 rubygem-gitlab-pygments.rb-0.5.4 rubygem-gitlab_emoji-0.1.0 rubygem-gitlab_git-7.1.13 rubygem-gitlab_meta-7.0 rubygem-gitlab_omniauth-ldap-1.2.1 rubygem-html-pipeline-gitlab-0.2.0 rubygem-omniauth-github-1.1.2 rubygem-omniauth-github-discourse-1.1.2 rubygem-omniauth-gitlab-1.0.0 sagittarius-scheme-0.6.3 svn2git-1.0.10 uwsgitop-0.8 wyrmgus-git20150601 xtgyoretsu-git20140822
root@pyload:/ # pkg_add -r git Error: Unable to get ftp://ftp.freebsd.org/pub/FreeBSD/ports/amd64/packages-9-stable/Latest/git.tbz: File unavailable (e.g., file not found, no access) pkg_add: unable to fetch 'ftp://ftp.freebsd.org/pub/FreeBSD/ports/amd64/packages-9-stable/Latest/git.tbz' by URL
root@pyload:/ # ping www.google.com PING www.google.com (173.194.45.82): 56 data bytes 64 bytes from 173.194.45.82: icmp_seq=0 ttl=55 time=7.994 ms 64 bytes from 173.194.45.82: icmp_seq=1 ttl=55 time=7.199 ms 64 bytes from 173.194.45.82: icmp_seq=2 ttl=55 time=8.201 ms 64 bytes from 173.194.45.82: icmp_seq=3 ttl=55 time=7.517 ms 64 bytes from 173.194.45.82: icmp_seq=5 ttl=55 time=7.331 ms 64 bytes from 173.194.45.82: icmp_seq=6 ttl=55 time=7.327 ms 64 bytes from 173.194.45.82: icmp_seq=8 ttl=55 time=8.377 ms 64 bytes from 173.194.45.82: icmp_seq=9 ttl=55 time=8.430 ms 64 bytes from 173.194.45.82: icmp_seq=10 ttl=55 time=8.182 ms 64 bytes from 173.194.45.82: icmp_seq=11 ttl=55 time=7.718 ms 64 bytes from 173.194.45.82: icmp_seq=12 ttl=55 time=7.239 ms
portsnap fetch extract
pkg update
pkg2ng
pkg install git
cd /usr/ports/www
git clone https://github.com/mrhanky17/pyload-freebsd.git pyload
cd pyload/
make makesum
make install clean
chmod -R 755 /usr/local/share/pyload/
pyload
echo 'pyload_enable="YES"' >> /etc/rc.conf echo 'pyload_flags="--daemon"' >> /etc/rc.confecho 'pyload_pid="/var/run/pyload.pid" ' >> /etc/rc.conf echo 'pyload_config="/root/pyload"' >> /etc/rc.conf ln -s /usr/ports/www/pyload/work/stage/usr/local/etc/rc.d/pyload /etc/rc.d/pyload
service pyload start
make makesum
