azentaja
 - Dec 27, 2021
Hardware: Microserver Gen10 plus, iLO addon card, USB 2&3 drives for the image, Samsung 840 SSD as the boot drive.
Software: Rufus 4.0.2035 used with the usb drives.
Hello, I'm unable to get past the following stage of installation. Installation has stopped about 5 times so far somewhere around these stages.
If it matters, Rufus prompted to load an older Grub, than what is supplied with it, which was done.
This thread discusses about the same issue: https://www.truenas.com/community/threads/truenas-scale-22-12-0-installation-errors.107642/
I let the installer run, and I've managed to login with the WebUI.
The question is, is there something missing from the initial installation? Can I continue configuring the software normally?
Error messages:
1:
2:
Error messages:
1:
[0%] Creating dataset [0%] Extracting ... [90%] Extracting [90%] Performing post-install tasks [ 484.402227] Tainted: P [ 484.398037] INFO: task txg_sync:1731 blocked for more than 120 seconds. OE 5.15.79+truenas #1 [ 484.406517] "echo 0> /proc/sys/kernel/hung_task_timeout_secs" disables this message.
2:
[46%] Extracting [46%] Extracting [49%] Extracting [50%] Extracting [51%] Extracting [ 363.566645] INFO: task txg_sync:1602 blocked for more than 120 seconds. [363.570257] Tainted: P OE 5.15.79+truenas #1 [363.574391] "echo > /proc/sys/kernel/hung_task_timeout_secs" disables this message. [53%) Extracting ... [84%) Extracting [87%) Extracting [90%] Extracting [90%] Performing post-install tasks [ 605.230624] INFO: task txg_sync:1602 blocked for more than 120 seconds. [ 605.235215] Tainted: P OE 5.15.79+truenas #1 [ 605.239656] "echo 0> /proc/sys/kernel/hung_task_timeout_secs" disables this message.
