Installation failed
larlap
Created install medium from ISO on Ubuntu using dd. When booted and choosing Install on an SSD, I see the following message:
File "/usr/local/bin/freenas-install", line 59, in <module>
   if installer.GetPackages() is not True:
File "/usr/local/lib/freenasOS/Installer.py", line 1072, in GetPackages
  pkgFile = self._conf.FindPackageFile(pkg, handler=get_file_handler)
File "/usr/local/lib/freenasOS/Configuration.py", line 1274, in FindPackageFile
  raise Exceptions.UpdatePackageNotFound(package.Name())
freenasOS.Exceptions.UpdatePackageNotFound: base-os
The FreeNAS installation on ada0 has failed. Press enter to continue...
Hardware
CPU Intel Xeon E3 1226 v3
RAM 16.0GB Dual-Channel DDR3 @ 800MHz
Motherboard Supermicro X10SLL+-F
Boot 465GB Samsung SSD 840 EVO 500GB
Should I copy the installation ISO to another flash drive?
Dan Tudora
hello
I use from my windows 10 laptop without problem Win32DiskImager-0.9.5-binary to write ISO pfsense, Truenas, Truenas Scale to USB stick
I try including rufus but not 100% success
but 100% percent work with that software (this version)
success
mazdajai
Having the same issue with two Dell R630 (PERC set to HBA).
Tried the following:
  • SSD, HDD and USB. (USB is brand new)
  • 11.2U8, 11.3U5 and 12.0
  • 2 identical Dell R630
  • BIOS or UEFI
Dan Tudora
  • BIOS or UEFI
hello
you resolve that problem ??
in many case this things has been resolved with bios/firmware update
at DELL servers that update can be do in the first/second screen for update platform
F10 key I think for update bios/firmware
try that and report after
success
mazdajai
No. The R630 is running the latest BIOS, this also fail on a Supermicro node with identical error.
Dan Tudora
hello
why do not try install from a CD/DVD (original media in fact, verified ISO with SHA) burned ??
maybe is something wrong with create USB install media
cheers
mazdajai
The iso was verified with sha256 on two different. The server is located in a remote datacenter so install via USB is discouraged.
This turns out to be a non-issue but rather a lack of installation progress. After trying different server hardware, hard drives, iso and even client machine. The installation eventually finished after 2hrs.
Kraneo
Hi, i'm new.
I am having the same problem installing TrueNAS on a ssd disk.
line 59 ... etc.
have you found any solution?
