markymark832
- Feb 28, 2017
quick question, when it comes to updating Heimdall is there a procedure? (if there is updates available)
Can't say that I have, but it's been a while since I did an installation with this script. TheHave you already experienced this ?
caddyv2 branch might work better.Can you please explain how you did it?That's exactly how I've set mine up. It works brilliantly!
You'd install Heimdall, then edit its Caddyfile following the examples here:Can you please explain how you did it?
Same issue here. I have been paying a lot with the CaddyFile, without any success.Thanks a lot! Installation is now working again!
However, i'm catching a 404 error when trying to reach http://JAILIP.
Tried with different versions of heimdall but still the same. Have you already experienced this ?
I will keep checking on my side!
Thanks again for the update of the script!
Not working either.I'm pretty sure you'd need to browse by FQDN.
:80 {
root * /usr/local/www/html/public
encode gzip
php_fastcgi 127.0.0.1:9000 {
env SERVER_PORT 80
file_server
log {
format json
output file /var/log/access.log {
roll_keep 7
# External access denied to these files.
@forbidden {
path /wp-content/uploads/*.php
path /.user.ini
path /wp-content/debug.log
respond @forbidden 404
Somewhat of an old question, but this GitHub issue seems relevant:when it comes to updating Heimdall is there a procedure?
TrueNAS 12 supports something like this (and it's the default way plugins are created), but I don't believe prior versions do.Started running RANCHER and you can create any number of CONTAINERS including Heimdall on the same IP, just a different port.
