Chris230291
- Mar 21, 2012
Hello. I have the transmission plugin running on my FreeNas machine and it works great. However, my AFP share that i use to access the downloads looses the ability for me to modify and delete files. If i do anything with the permissions on the data set the share is linked to, i regain read/write access and break transmission. Is there any way to have both working at the same time?
I used this guide to set transmission up...
I have a dataset called "media" with a folder called "downloads" inside it. I am the owner and the group is set to wheel. I have a mount point which joins /raid-set/media/downloads to /usr/downloads inside the jail.
Does anyone know what could be causing my issue?
Thanks,
Chris.
Thanks,
Chris.
