If is possbile for hotbackup files from ZpoolA to ZpoolB ?
skyyxy
Hi Everybody here. I have a small question, but don't know how to do.
I have a Freenas Server in the office and want to creat 2 zpools. ZpoolA for work files and ZpoolB backup. My question is any idea to make ZpoolB to be a backup for ZpoolA like Rsync but just backup in local service not network? Thanks a lot advance.
Another small question. I know since Freenas new verion start to use new default GUI, any idea change to the old GUI as default just still like old.
Snapshot and replication when configuring replication target enter localhost and point it at the relevant dataset.
skyyxy
Chris Moore
When accessing the the GUI, add /legacy to the end of the URL. It will automatically use the legacy interface, but you need to get accustomed to the new GUI sooner or later because they will eventually drop support for the legacy UI. The developers don't like it.
How is your current pool constructed? I note you have 2 x 2TB disks for data. Are they in a mirror? If not, I think you have more fundamental issues to address than snapshot and replication.
Chris Moore
intel i3 2100
Asus h61
8gb ddr3 1333
80GB seagate hdd for system
2*2TB for date
Freenas 9.3
Really?
You might need to consider a little hardware upgrade and possibly even a newer version of the software?
