Nick Savopoulos
 - Oct 22, 2016
Hello FreeNAS community, i am a very new freenas happy user.
I installed FreeNAS couple months ago i already solved many problems i had using this forum but now i need some help on a security report i am getting in my email.
Can someone please spare some of his time and tell me why i get these messages couple of days now. I would apreacciate any help
Security Messages:
1- Why i have Up-Down link states the last couple days?
2- Why it says GEOM_ELI: Device ada1p1.eli destroyed. > GEOM_ELI: Detached ada1p1.eli on last close.
3- Why i loose memory? Freed UMA keg (udp_inpcb) was not empty (120 items). Lost 12 pages of memory.
My Configuration is:
System Information
Build FreeNAS-9.10.1 (d989edd)
Platform Intel(R) Core(TM) i5-2500 CPU @ 3.30GHz
Memory 8074MB
System Time Sat Oct 22 11:33:02 EEST 2016
Uptime 11:33AM up 1 day, 1:22, 0 users
Load Average 0.40, 0.22, 0.17
Thank you for your time
Security Messages:
> re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > pid 1446 (syslog-ng), uid 0: exited on signal 6 (core dumped) > GEOM_ELI: Device ada1p1.eli destroyed. > GEOM_ELI: Detached ada1p1.eli on last close. > GEOM_ELI: Device ada0p1.eli destroyed. > GEOM_ELI: Detached ada0p1.eli on last close. > GEOM_ELI: Device ada2p1.eli destroyed. > GEOM_ELI: Detached ada2p1.eli on last close. > GEOM_ELI: Device ada3p1.eli destroyed. > GEOM_ELI: Detached ada3p1.eli on last close. > epair0a: link state changed to DOWN > epair0b: link state changed to DOWN > re0: link state changed to DOWN > bridge0: link state changed to DOWN > re0: promiscuous mode disabled > ifa_del_loopback_route: deletion failed: 48 > Freed UMA keg (udp_inpcb) was not empty (120 items). Lost 12 pages of memory. > Freed UMA keg (udpcb) was not empty (1169 items). Lost 7 pages of memory. > Freed UMA keg (tcptw) was not empty (270 items). Lost 6 pages of memory. > Freed UMA keg (tcp_inpcb) was not empty (120 items). Lost 12 pages of memory. > Freed UMA keg (tcpcb) was not empty (36 items). Lost 12 pages of memory. > Freed UMA keg (ripcb) was not empty (120 items). Lost 12 pages of memory. > hhook_vnet_uninit: hhook_head type=1, id=1 cleanup required > hhook_vnet_uninit: hhook_head type=1, id=0 cleanup required > Waiting (max 60 seconds) for system process `vnlru' to stop...done > Waiting (max 60 seconds) for system process `bufdaemon' to stop...done > Waiting (max 60 seconds) for system process `syncer' to stop... > Syncing disks, vnodes remaining...0 0 0 0 0 done > All buffers synced. > Copyright (c) 1992-2016 The FreeBSD Project. > Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994 > The Regents of the University of California. All rights reserved. > FreeBSD is a registered trademark of The FreeBSD Foundation. > FreeBSD 10.3-STABLE #0 r295946=5327704(9.10-STABLE): Wed Aug 3 12:13:26 PDT 2016 > root@build.ixsystems.com:/tank/home/nightlies/build-freenas9/_BE/objs/tank/home/nightlies/build-freenas9/_BE/os/sys/FreeNAS.amd64 amd64 > FreeBSD clang version 3.4.1 (tags/RELEASE_34/dot1-final 208032) 20140512 > CPU: Intel(R) Core(TM) i5-2500 CPU @ 3.30GHz (3291.76-MHz K8-class CPU) > Origin="GenuineIntel" Id=0x206a7 Family=0x6 Model=0x2a Stepping=7 > Features=0xbfebfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,DTS,ACPI,MMX,FXSR,SSE,SSE2,SS,HTT,TM,PBE> > Features2=0x1fbae3ff<SSE3,PCLMULQDQ,DTES64,MON,DS_CPL,VMX,SMX,EST,TM2,SSSE3,CX16,xTPR,PDCM,PCID,SSE4.1,SSE4.2,x2APIC,POPCNT,TSCDLT,AESNI,XSAVE,OSXSAVE,AVX> > AMD Features=0x28100800<SYSCALL,NX,RDTSCP,LM> > AMD Features2=0x1<LAHF> > XSAVE Features=0x1<XSAVEOPT> > VT-x: PAT,HLT,MTF,PAUSE,EPT,UG,VPID > TSC: P-state invariant, performance statistics > real memory = 9661579264 (9214 MB) > avail memory = 8166600704 (7788 MB) > Event timer "LAPIC" quality 600 > ACPI APIC Table: <ALASKA A M I> > FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs > FreeBSD/SMP: 1 package(s) x 4 core(s) > cpu0 (BSP): APIC ID: 0 > cpu1 (AP): APIC ID: 2 > cpu2 (AP): APIC ID: 4 > cpu3 (AP): APIC ID: 6 > random: <Software, Yarrow> initialized > WARNING: VIMAGE (virtualized network stack) is a highly experimental feature. > ioapic0 <Version 2.0> irqs 0-23 on motherboard > kbd1 at kbdmux0 > aesni0: <AES-CBC,AES-XTS> on motherboard > padlock0: No ACE support. > cryptosoft0: <software crypto> on motherboard > acpi0: <ALASKA A M I> on motherboard > acpi0: Power Button (fixed) > cpu0: <ACPI CPU> on acpi0 > cpu1: <ACPI CPU> on acpi0 > cpu2: <ACPI CPU> on acpi0 > cpu3: <ACPI CPU> on acpi0 > attimer0: <AT timer> port 0x40-0x43 irq 0 on acpi0 > Timecounter "i8254" frequency 1193182 Hz quality 0 > Event timer "i8254" frequency 1193182 Hz quality 100 > atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0 > Event timer "RTC" frequency 32768 Hz quality 0 > hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0 > Timecounter "HPET" frequency 14318180 Hz quality 950 > Event timer "HPET" frequency 14318180 Hz quality 550 > Event timer "HPET1" frequency 14318180 Hz quality 440 > Event timer "HPET2" frequency 14318180 Hz quality 440 > Event timer "HPET3" frequency 14318180 Hz quality 440 > Event timer "HPET4" frequency 14318180 Hz quality 440 > Timecounter "ACPI-fast" frequency 3579545 Hz quality 900 > acpi_timer0: <24-bit timer at 3.579545MHz> port 0x408-0x40b on acpi0 > pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0 > pci0: <ACPI PCI bus> on pcib0 > pcib1: <ACPI PCI-PCI bridge> irq 16 at device 1.0 on pci0 > pci1: <ACPI PCI bus> on pcib1 > vgapci0: <VGA-compatible display> port 0xf000-0xf03f mem 0xfe000000-0xfe3fffff,0xc0000000-0xcfffffff irq 16 at device 2.0 on pci0 > agp0: <SandyBridge desktop GT1 IG> on vgapci0 > agp0: aperture size is 256M, detected 65532k stolen memory > vgapci0: Boot video device > pci0: <simple comms> at device 22.0 (no driver attached) > ehci0: <EHCI (generic) USB 2.0 controller> mem 0xfe606000-0xfe6063ff irq 23 at device 26.0 on pci0 > usbus0: EHCI version 1.0 > usbus0 on ehci0 > pci0: <multimedia, HDA> at device 27.0 (no driver attached) > pcib2: <ACPI PCI-PCI bridge> irq 17 at device 28.0 on pci0 > pci2: <ACPI PCI bus> on pcib2 > pcib3: <ACPI PCI-PCI bridge> irq 16 at device 28.1 on pci0 > pci3: <ACPI PCI bus> on pcib3 > pcib4: <ACPI PCI-PCI bridge> irq 18 at device 28.2 on pci0 > pci4: <ACPI PCI bus> on pcib4 > re0: <RealTek 8168/8111 B/C/CP/D/DP/E/F/G PCIe Gigabit Ethernet> port 0xe000-0xe0ff mem 0xd0004000-0xd0004fff,0xd0000000-0xd0003fff irq 18 at device 0.0 on pci4 > re0: Using 1 MSI-X message > re0: Chip rev. 0x2c800000 > re0: MAC rev. 0x00100000 > miibus0: <MII bus> on re0 > rgephy0: <RTL8169S/8110S/8211 1000BASE-T media interface> PHY 1 on miibus0 > rgephy0: none, 10baseT, 10baseT-FDX, 10baseT-FDX-flow, 100baseTX, 100baseTX-FDX, 100baseTX-FDX-flow, 1000baseT, 1000baseT-master, 1000baseT-FDX, 1000baseT-FDX-master, 1000baseT-FDX-flow, 1000baseT-FDX-flow-master, auto, auto-flow > re0: Using defaults for TSO: 65518/35/2048 > re0: Ethernet address: 54:04:a6:96:19:24 > pcib5: <ACPI PCI-PCI bridge> irq 19 at device 28.3 on pci0 > pci5: <ACPI PCI bus> on pcib5 > xhci0: <ASMedia ASM1042 USB 3.0 controller> mem 0xfe500000-0xfe507fff irq 19 at device 0.0 on pci5 > xhci0: 32 bytes context size, 32-bit DMA > usbus1 on xhci0 > pcib6: <ACPI PCI-PCI bridge> irq 17 at device 28.4 on pci0 > pci6: <ACPI PCI bus> on pcib6 > pcib7: <ACPI PCI-PCI bridge> irq 16 at device 28.5 on pci0 > pci7: <ACPI PCI bus> on pcib7 > ahci0: <ASMedia ASM1061 AHCI SATA controller> port 0xd050-0xd057,0xd040-0xd043,0xd030-0xd037,0xd020-0xd023,0xd000-0xd01f mem 0xfe400000-0xfe4001ff irq 17 at device 0.0 on pci7 > ahci0: AHCI v1.20 with 2 6Gbps ports, Port Multiplier supported > ahcich0: <AHCI channel> at channel 0 on ahci0 > ahcich1: <AHCI channel> at channel 1 on ahci0 > ehci1: <EHCI (generic) USB 2.0 controller> mem 0xfe605000-0xfe6053ff irq 23 at device 29.0 on pci0 > usbus2: EHCI version 1.0 > usbus2 on ehci1 > isab0: <PCI-ISA bridge> at device 31.0 on pci0 > isa0: <ISA bus> on isab0 > atapci0: <Intel Cougar Point SATA600 controller> port 0xf110-0xf117,0xf100-0xf103,0xf0f0-0xf0f7,0xf0e0-0xf0e3,0xf0d0-0xf0df,0xf0c0-0xf0cf irq 20 at device 31.2 on pci0 > ata2: <ATA channel> at channel 0 on atapci0 > ata3: <ATA channel> at channel 1 on atapci0 > atapci1: <Intel Cougar Point SATA300 controller> port 0xf0b0-0xf0b7,0xf0a0-0xf0a3,0xf090-0xf097,0xf080-0xf083,0xf070-0xf07f,0xf060-0xf06f irq 20 at device 31.5 on pci0 > ata4: <ATA channel> at channel 0 on atapci1 > ata5: <ATA channel> at channel 1 on atapci1 > acpi_button0: <Power Button> on acpi0 > uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0 > ichwd0: <Intel Cougar Point watchdog timer> on isa0 > wbwd0: <Nuvoton NCT6776 (0xc3/0x33) Watchdog Timer> at port 0x2e-0x2f on isa0 > orm0: <ISA Option ROM> at iomem 0xc0000-0xcdfff on isa0 > sc0: <System console> at flags 0x100 on isa0 > sc0: VGA <16 virtual consoles, flags=0x300> > vga0: <Generic ISA VGA> at port 0x3c0-0x3df iomem 0xa0000-0xbffff on isa0 > atkbdc0: <Keyboard controller (i8042)> at port 0x60,0x64 on isa0 > atkbd0: <AT Keyboard> irq 1 on atkbdc0 > kbd0 at atkbd0 > atkbd0: [GIANT-LOCKED] > coretemp0: <CPU On-Die Thermal Sensors> on cpu0 > est0: <Enhanced SpeedStep Frequency Control> on cpu0 > coretemp1: <CPU On-Die Thermal Sensors> on cpu1 > est1: <Enhanced SpeedStep Frequency Control> on cpu1 > coretemp2: <CPU On-Die Thermal Sensors> on cpu2 > est2: <Enhanced SpeedStep Frequency Control> on cpu2 > coretemp3: <CPU On-Die Thermal Sensors> on cpu3 > est3: <Enhanced SpeedStep Frequency Control> on cpu3 > random: unblocking device. > usbus0: 480Mbps High Speed USB v2.0 > ZFS filesystem version: 5 > ZFS storage pool version: features support (5000) > Timecounters tick every 1.000 msec > ipfw2 (+ipv6) initialized, divert enabled, nat enabled, default to accept, logging disabled > usbus1: 5.0Gbps Super Speed USB v3.0 > usbus2: 480Mbps High Speed USB v2.0 > ugen1.1: <0x1b21> at usbus1 > uhub0: <0x1b21 XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus1 > ugen0.1: <Intel> at usbus0 > uhub1: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus0 > ugen2.1: <Intel> at usbus2 > uhub2: <Intel EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus2 > uhub0: 4 ports with 4 removable, self powered > uhub2: 2 ports with 2 removable, self powered > uhub1: 2 ports with 2 removable, self powered > ugen0.2: <vendor 0x8087> at usbus0 > uhub3: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus0 > ugen2.2: <vendor 0x8087> at usbus2 > uhub4: <vendor 0x8087 product 0x0024, class 9/0, rev 2.00/0.00, addr 2> on usbus2 > uhub3: 4 ports with 4 removable, self powered > uhub4: 6 ports with 6 removable, self powered > ugen0.3: <Generic> at usbus0 > umass0: <Generic Mass Storage, class 0/0, rev 2.00/1.06, addr 3> on usbus0 > umass0: SCSI over Bulk-Only; quirks = 0x4101 > umass0:7:0:-1: Attached to scbus7 > ugen2.3: <Microsoft> at usbus2 > ugen2.4: <Microsoft> at usbus2 > ukbd0: <Microsoft Wired Keyboard 400, class 0/0, rev 2.00/3.00, addr 4> on usbus2 > kbd2 at ukbd0 > ada0 at ahcich0 bus 0 scbus0 target 0 lun 0 > ada0: <WDC WD15EARS-00MVWB0 51.0AB51> ATA8-ACS SATA 2.x device > ada0: Serial Number WD-WCAZA1695050 > ada0: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) > ada0: Command Queueing enabled > ada0: 1430799MB (2930277168 512 byte sectors) > ada0: quirks=0x1<4K> > ada0: Previously was known as ad4 > ada1 at ahcich1 bus 0 scbus1 target 0 lun 0 > ada1: <WDC WD15EARS-00MVWB0 51.0AB51> ATA8-ACS SATA 2.x device > ada1: Serial Number WD-WCAZA1787155 > ada1: 300.000MB/s transfers (SATA 2.x, UDMA6, PIO 8192bytes) > ada1: Command Queueing enabled > ada1: 1430799MB (2930277168 512 byte sectors) > ada1: quirks=0x1<4K> > ada1: Previously was known as ad6 > ada2 at ata4 bus 0 scbus4 target 0 lun 0 > ada2: <WDC WD10EZEX-21M2NA0 01.01A01> ACS-2 ATA SATA 3.x device > ada2: Serial Number WCC3F0474180 > ada2: 300.000MB/s transfers (SATA 2.x, UDMA5, PIO 8192bytes) > ada2: 953869MB (1953525168 512 byte sectors) > ada2: Previously was known as ad12 > ada3 at ata5 bus 0 scbus5 target 0 lun 0 > ada3: <ST31000524AS JC45> ATA8-ACS SATA 3.x device > ada3: Serial Number 6VPBY30A > ada3: 300.000MB/s transfers (SATA 2.x, UDMA5, PIO 8192bytes) > ada3: 953869MB (1953525168 512 byte sectors) > ada3: Previously was known as ad14 > cd0 at ata2 bus 0 scbus2 target 0 lun 0 > cd0: <TSSTcorp CDDVDW SH-224BB SB00> Removable CD-ROM SCSI device > cd0: Serial Number R8WS68DC9016D8 > cd0: 150.000MB/s transfers (SATA 1.x, UDMA5, ATAPI 12bytes, PIO 8192bytes) > cd0: Attempt to query device size failed: NOT READY, Medium not present - tray closed > da0 at umass-sim0 bus 0 scbus7 target 0 lun 0 > da0: <Generic Flash Disk 8.07> Removable Direct Access SPC-2 SCSI device > da0: Serial Number 94A547E9 > da0: 40.000MB/s transfers > da0: 15000MB (30720000 512 byte sectors) > da0: quirks=0x2<NO_6_BYTE> > SMP: AP CPU #1 Launched! > SMP: AP CPU #3 Launched! > SMP: AP CPU #2 Launched! > Timecounter "TSC-low" frequency 1645881960 Hz quality 1000 > Trying to mount root from zfs:freenas-boot/ROOT/9.10.1 []... > GEOM_RAID5: Module loaded, version 1.3.20140711.62 (rev f91e28e40bf7) > re0: link state changed to UP > ugen2.3: <Microsoft> at usbus2 (disconnected) > ugen2.3: <Microsoft> at usbus2 > hwpmc: SOFT/16/64/0x67<INT,USR,SYS,REA,WRI> TSC/1/64/0x20<REA> IAP/8/48/0x3ff<INT,USR,SYS,EDG,THR,REA,WRI,INV,QUA,PRC> IAF/3/48/0x67<INT,USR,SYS,REA,WRI> UCP/8/48/0x3f8<EDG,THR,REA,WRI,INV,QUA,PRC> UCF/1/48/0x60<REA,WRI> > re0: link state changed to DOWN > ums0: <Microsoft Microsoft Basic Optical Mouse v2.0, class 0/0, rev 1.10/1.04, addr 3> on usbus2 > ums0: 3 buttons and [XYZ] coordinates ID=0 > vboxdrv: fAsync=0 offMin=0x336 offMax=0xc36 > GEOM_ELI: Device ada1p1.eli created. > GEOM_ELI: Encryption: AES-XTS 128 > GEOM_ELI: Crypto: hardware > GEOM_ELI: Device ada0p1.eli created. > GEOM_ELI: Encryption: AES-XTS 128 > GEOM_ELI: Crypto: hardware > GEOM_ELI: Device ada2p1.eli created. > GEOM_ELI: Encryption: AES-XTS 128 > GEOM_ELI: Crypto: hardware > GEOM_ELI: Device ada3p1.eli created. > GEOM_ELI: Encryption: AES-XTS 128 > GEOM_ELI: Crypto: hardware > re0: link state changed to UP > bridge0: Ethernet address: 02:6f:82:77:1a:00 > re0: promiscuous mode enabled > bridge0: link state changed to UP > epair0a: Ethernet address: 02:ff:20:00:04:0a > epair0b: Ethernet address: 02:ff:70:00:05:0b > epair0a: link state changed to UP > epair0b: link state changed to UP > epair0a: promiscuous mode enabled > re0: link state changed to DOWN > ng_ether_ifnet_arrival_event: can't re-name node epair0b > ahcich0: Timeout on slot 16 port 0 > ahcich0: is 00000000 cs 00030000 ss 00030000 rs 00030000 tfd 451 serr 00000000 cmd 0004d117 > (ada0:ahcich0:0:0:0): READ_FPDMA_QUEUED. ACB: 60 10 00 d2 58 40 03 00 00 00 00 00 > (ada0:ahcich0:0:0:0): CAM status: Command timeout > (ada0:ahcich0:0:0:0): Retrying command > ahcich1: Timeout on slot 0 port 0 > ahcich1: is 00000000 cs 0000000f ss 0000000f rs 0000000f tfd 451 serr 00000000 cmd 0004c317 > (ada1:ahcich1:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 80 00 00 40 00 00 00 01 00 00 > (ada1:ahcich1:0:0:0): CAM status: Command timeout > (ada1:ahcich1:0:0:0): Retrying command > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN > re0: link state changed to UP > re0: link state changed to DOWN
System Information
Memory 8074MB
