Hi there,
I switched my installation from TrueNAS CORE to SCALE. The transition went very quickly, with no particular problems.
I have a question of understanding: we're talking about container support (docker) which is supported on SCALE. Are we talking about Apps inside the TrueNAS installation that use this technology? On the other hand, we're not talking about a Debian system with the option of using docker and containers outside TrueNAS, is that correct?
Thank you
Thank you
