I switched to SCALE, what's next?
owegen
Hi there,
I switched my installation from TrueNAS CORE to SCALE. The transition went very quickly, with no particular problems.
I have a question of understanding: we're talking about container support (docker) which is supported on SCALE. Are we talking about Apps inside the TrueNAS installation that use this technology? On the other hand, we're not talking about a Debian system with the option of using docker and containers outside TrueNAS, is that correct?
Thank you
Patrick M. Hausen
Correct and correct. You cannot (well, you can force it, but you will probably break your TrueNAS) install anything outside of the supported apps and VMs.
sfatula
Big blue button, Launch Docker Image works fine and doesn't break anything. Certainly supported else it wouldn't be in the UI.
