I just moved from scale to core and how does the ssh work in core?
sennebo
As you know, i recently moved from scale to core.
I learned quickly and created an smb share with the right permissions on a mirror.
One thing that is completely different is ssh. On scale i could just ssh into it by using ssh admin@[my domain]
But now i need to paste keys and stuff?
Is there a way so i could use the good old ssh from Scale?
Where do you get this idea?
The key (relevant) difference between CORE and SCALE is that iX is pushing for non-root admin users in SCALE, while there's no such thing in CORE. Go to Services -> SSH -> configure and enable root login with password.
anodos
Sambassador
BTW, this is getting extended in DragonFish so that you can have limited admin users where portions of UI are disabled. Our middleware is basically becoming multi-user with auditing, RBAC, and such.
Though my post above indicates (correctly) that you don't need to use public-key authentication (in CORE or SCALE), it's a good idea in either. But again, it's nothing about CORE vs. SCALE.
anodos
Sambassador
Right. There's no difference in that regard. ssh works like it always has. Generally best-practice is to use key-based-auth, but if this is home NAS that is not exposed to internet password-based auth is fine.
sennebo
i moved from core to scale not the other way. in scale i can just use ssh without those keys and in core i have to copy a key
