https there is a problem connecting middleware
Nicolas_Studiokgb
Hi all :)
When I want to connect to truecommand through https I get this message :
"Connection Error
There's a problem connecting the middleware."
in http with the "no ssl" port assigned it work fine.
Notice : It was working perfectly yesterday...
any idea ?
Nicolas
Nicolas_Studiokgb
Hello i
It seems that when connecting to truecommand from firefox . when I add the exception and say to connect to the server, It ask to use a certificate that I think has nothing to do with truecommand (one wich should be install in my laptop for another use. If I click cancel, it connect fine. I don't understand this behaviour. It only happen with truecommand. Not with Truenas for exemple
I have cleaned all the item relating to the trueecommand IP adress in firefox security.
Same in chrome but it doesn't connect at all. (but I never use chrome so I don't care)
We have no certificate in the installation for now.
I'll check if this popup show up again and we'll see.
I'm only testing Truecommand for now.
