I would imagine the HP DL 140 3rd generation, which is what I believe you're referring to, will work fine. However, from the specs, it looks like it comes with quite a complicated set of disk controllers. Almost assuredly, there will be considerable work to do making sure that the controllers are configured in such a way that you are not making a ticking time bomb. But there's forum posts on that.
From memory, the only one that will behave properly with FreeNAS is the SATA non-hotswap version. All of the others won't pass the disks through when left unconfigured.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
