- Nov 25, 2013
Yes, it works precisely this way. My procedure is not necessary for fresh installs.
EDIT: ended up following this guide, works perfectly nowI'm not sure if maybe such an involved process was required when Scale first became available, however, at this point in time this process is overly complicated for Scale. All you need to do is change literally one line in the install script before starting it and it will create a smaller partition on the boot drive. It's a simple single sed statement. I'll try to post the exact statement I used when I'm back at my computer.
Thanks,
Harry
Finally getting back to this ... for those that asked about this, all you have to do is select the Shell option option in the installation GUI and run the following command:I'm not sure if maybe such an involved process was required when Scale first became available, however, at this point in time this process is overly complicated for Scale. All you need to do is change literally one line in the install script before starting it and it will create a smaller partition on the boot drive. It's a simple single sed statement. I'll try to post the exact statement I used when I'm back at my computer.
Thanks,
Harry
sed -i 's/sgdisk -n3:0:0/sgdisk -n3:0:+16G/' /usr/sbin/truenas-install
truenas-install
Thank you so much. Everything worked out.Hi all,
first of all: this is an unsupported configuration. I run it myself for quite some time and I'm confident that it will continue to work, but you proceed at your own risk.
1. Motivation
Current series of new SSDs frequently start at 250 GB or even 500 GB size. It is a waste of space and money to only put the boot pool on a drive this large. OTOH in a production installation it is highly desirable to use SSDs instead of USB thumb drives.
My system has two SSDs for the boot pool and another pool with virtual machines. The ZVOLs in the latter are regularly replicated to my main data pool (RAIDZ2) comprised of spinning disks.
2. Prerequisites
If you already run FreeNAS from one or two SSDs that you like to repurpose, you must perform a fresh installation. It is not possible to shrink a vdev, so we need to repartition.
Parts:
My target drives:
- 1 USB drive of suitable size, 16 or 32 GB
- 1, better 2 SSDs for the boot pool and additional data
Code:ada4: <Samsung SSD 860 PRO 512GB RVM01B6Q> ACS-4 ATA SATA 3.x device ada4: Serial Number S42YNX0MA13733E ada4: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 512bytes) ada4: Command Queueing enabled ada4: 488386MB (1000215216 512 byte sectors) ada5 at ahcich5 bus 0 scbus5 target 0 lun 0 ada5: <Samsung SSD 860 PRO 512GB RVM01B6Q> ACS-4 ATA SATA 3.x device ada5: Serial Number S42YNX0MA13643E ada5: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 512bytes) ada5: Command Queueing enabled ada5: 488386MB (1000215216 512 byte sectors)
I'll assume UEFI boot throughout this post.
3. Preparation
As stated, if you are already running the system, a complete reinstall is necessary, so:
4. Install to the USB drive
- Backup your configuration
- Export your data pools from the UI
Use your preferred method (I frequently use VMware Fusion on my Mac) to perform a fresh FreeNAS install. Actually there's nothing that fundamentally prohibits what we are trying to achieve now, it is just the installer that won't let us partition the system drive(s) manually. Hence the workaround with a smaller initial drive.
5. Boot the USB installation
This should be easy using the boot menu of your EFI BIOS. The tricky part is that you want to make sure you are really running off the USB drive and don't import and mount the pool still on your SSDs. They are both named the same ("boot-pool"), so the system might get confused. I do not have the time to try it in a VM and do a transcript. Up to this point you will definitely not damage anything, stay calm ;)
6. Enable SSH and login
Configure the "new" FreeNAS installation to the point where you can get a shell via SSH. Then do
Code:zpool status boot-pool pool: boot-pool state: ONLINE config: NAME STATE READ WRITE CKSUM boot-pool ONLINE 0 0 0 da0p2 ONLINE 0 0 0 errors: No known data errors
So we are running from USB (da0) ...
7. Wipe your SSDs
My SSDs are ada4 and ada5 (see above), ada0 - ada3 are the spinning disks that build my main storage pool. Danger, Will Robinson! We are deleting the old installation, now. Don't confuse the disk drives!
Code:zpool labelclear ada4p2 zpool labelclear ada5p2 gpart delete -i2 ada4 gpart delete -i2 ada5 gpart delete -i1 ada4 gpart delete -i1 ada5 gpart destroy ada4 gpart destroy ada5
8. Transfer the new system to the SSDs
Copy the partition table:
Code:gpart backup da0 | gpart restore ada4 gpart backup da0 | gpart restore ada5
Attach the devices to the zpool:
Code:zpool attach boot-pool da0p2 ada4p2 zpool attach boot-pool da0p2 ada5p2
Copy the EFI boot partition:
Code:dd if=/dev/da0p1 of=/dev/ada4p1 dd if=/dev/da0p1 of=/dev/ada5p1
Wait for the resilver to finish! (should not take long)
Detach the USB drive from the pool:
Code:zpool offline boot-pool da0p2 zpool detach boot-pool da0p2
Result:
Code:zpool status boot-pool pool: boot-pool state: ONLINE scan: scrub repaired 0 in 0 days 00:00:02 with 0 errors on Thu Jan 9 03:45:02 2020 config: NAME STATE READ WRITE CKSUM boot-pool ONLINE 0 0 0 mirror-0 ONLINE 0 0 0 ada4p2 ONLINE 0 0 0 ada5p2 ONLINE 0 0 0 errors: No known data errors gpart show ada4 => 40 1000215136 ada4 GPT (477G) 40 2008 - free - (1.0M) 2048 524288 1 efi (256M) 526336 67108864 2 freebsd-zfs (32G) 67635200 932579976 - free - (445G)
You should have quite some free space on your SSDs, now.
9. Shutdown, unplug the USB drive, boot from your SSDs, restore services
If the system boots alright, you might want to take the time to import your main data pool and restore your configuration, now.
Apart from the smaller partition size (which the installer refuses to create) there is absolutely nothing different from a regular install. So unless some future upgrade decides to wipe and repartition the system drives during the process this setup will definitely work like any other. We had that (wipe and repartition) once in the past when FreeNAS switched from UFS to ZFS for the boot drive. There might be a situation in the future when the boot loader changes (again) - you are on your own, watch the release notes for every major upgrade!
10. Create a new pool in the available space
Again we will need the command line, when we are finished the pool will be available in the GUI like any other:
Code:gpart add -t freebsd-zfs -a 1m ada4 gpart add -t freebsd-zfs -a 1m ada5 gpart list ada4 gpart list ada5
Look for these in the output of thegpart list
command:
Code:3. Name: ada4p3 [...] rawuuid: 25fe934a-19d6-11ea-82a1-ac1f6b76641c [...] 3. Name: ada5p3 [...] rawuuid: 3fc8e29a-19d0-11ea-9848-ac1f6b76641c
Now create the pool - use the UUIDs from the previous step:
Code:zpool create ssd mirror gptid/25fe934a-19d6-11ea-82a1-ac1f6b76641c gptid/3fc8e29a-19d0-11ea-9848-ac1f6b76641c
Last we export the pool from the command line:
Code:zpool export ssd
11. Import the new pool from the GUI
Done! Enjoy :)
Patrick
Edit 20210514: replace "freenas-boot" with "boot-pool" for current versions
Why "precious SSD space"? The clear advice is to go small and CHEAP for the boot drive, and not to mind about "wasted space"—think rather about "wasted time" hacking around the expectations of an appliance OS.This is much less critical in terms of data protection but does not completely waste the precious SSD space.
Thanks for the response. After doing more research I guess I was a bit overzealous; I found that in my case in a warm system the metadata is cached in ARC anyways and I can ls -R my million files (all residing on hdds) within a second. I'm using the new 23.10 RC with zfs 2.2.Why "precious SSD space"? The clear advice is to go small and CHEAP for the boot drive, and not to mind about "wasted space"—think rather about "wasted time" hacking around the expectations of an appliance OS.
L2ARC—assuming a L2ARC is useful at all—would best require a high-endurance SSD. Running L2ARC on the extra space of an old 256 GB SSD serving as boot drive may end up wearing out the boot drive. Oops!
If you have a use for L2ARC, and meet the hardware requirements for it (reminder: at least 64 GB for CORE, 96 GB for SCALE!), you can afford a discrete L2ARC drive.
//Before install, start shell (actually I used vi but this is a clear description of what to do) # sed -i 's/sgdisk -n3:0:0/sgdisk -n3:0:+32G/' /usr/sbin/truenas-install // Then run truenas-install // After install: # parted /dev/nvme0n1 GNU Parted 3.4 Using /dev/nvme0n1 Welcome to GNU Parted! Type 'help' to view a list of commands. (parted) print free Model: SAMSUNG XYZ (nvme) Disk /dev/nvme0n1: 512GB Sector size (logical/physical): 512B/512B Partition Table: gpt Disk Flags: pmbr_boot Number Start End Size File system Name Flags 17.4kB 2097kB 2080kB Free Space 1 2097kB 3146kB 1049kB bios_grub, legacy_boot 2 3146kB 540MB 537MB fat32 boot, esp 4 540MB 17.7GB 17.2GB swap 3 17.7GB 52.1GB 34.4GB zfs 52.1GB 512GB 460GB Free Space (parted) mkpart Partition name? []? File system type? [ext2]? zfs Start? 52.1GB <-- Equal to Start of Free Space entry End? 512GB <-- Equal to End of Free space entry # blkid /dev/nvme0n1p5 /dev/nvme0n1p5: LABEL="boot-pool" UUID="12851368433026806858" UUID_SUB="13930648100761960720" BLOCK_SIZE="4096" TYPE="zfs_member" PARTUUID="5b5bd244-a7f9-416f-b145-57f9dd0de8e2" <-- !! Careful here, not sure why it's named boot-pool for me, had to verify that this was the right one !! # zpool create -f nvmePool /dev/disk/by-partuuid/5b5bd244-a7f9-416f-b145-57f9dd0de8e2 # zpool export nvmePool // Now go into UI and import your pool -
I am trying to install the NAS for the first time so this is a free install on 500GB SSD. so which steps do i have to omit from these steps? Please confirm.Moderator Warning: This HOWTO will damage the ability of your TrueNAS appliance to properly maintain itself, will break the ability to replace failed drives, and may cause problems with upgrades and updates. TrueNAS is not designed to do this sort of partitioning, and the developers are not interested in supporting this. You may be on your own if you do this. Further discussion of the topic is available here in this resource.
Hi all,
1. Motivation
2. Prerequisites
Parts:
My target drives:
3. Preparation
7. Wipe your SSDs
Result:
command:
Done! Enjoy :)
Patrick
Is there any reason the shorter method wouldn't work if you exported the config and zfs pool of the original system, did a fresh install, and imported both?Yes, it works precisely this way. My procedure is not necessary for fresh installs.
