HowTO run openVPN client in Cobia
eiuep
I have been using Core for several years and just jumped in Scale - Cobia
I understood OpenVPN servers and client services were deprecated in Scale
I have an OpenVPN server I would like to connect to access the NAS ( I don't have public IP since under NAT of mobile networks) from the web
Can anyone give me suggestions to have the Cobia connected to OpenVPN server?
Thanks for your reply
ABain
Bug Conductor
If you scroll down this page, you can find a Migrating from OpenVPN service section, the OpenVPN service is not replaced with an app.
eiuep
Hi, Thanks for your reply
For sure I did save all the data about certificates and OpenVPN configuration before upgrading
from Core to Cobia.
Now the problem is that there is no OpenVPN client service embedded in Cobia, because it is said
to be supported by App but .... I couldn't find any app from iXsystem repository nor in TrueCharts that supports
OpenVPN connection to server so I feel disappointed.
If I am wrong please give me suggestions just to solve this issue.
Hopefully I am wrong but so far I feel not crystal releasing Cobia removing OpenVPN and at same
time having pools not backward compatible to downgrade to any Scale release having OpenVPN service enabled.
Other people suffer this issue.
so please support ...
I installed WG Easy but this is a VPN server, not a client for OpenVPN
eiuep
Thanks for the suggestion :) .. I will try to install in spare time and then come back to you for feedback
