How to use my 2nd NIC
john.doe79
I'm pretty sure you can't add em0 into the same bridge where you have a completely different subnet and the LAGG assigned.
Well... seems you can, but I don't expect it to work properly.
It isn't, or it shouldn't. igb2 & igb3 are part of the lagg0, lagg0 is part of of bridge0. em0 is just a single interface, which is down at the moment. Also interessting it says that igb4 is up, but nothing else is connected atm.
But it's also a member of the bridge which contains the LAGG interface...
    description: Bridge at lagg0
    ether 58:9c:fc:10:ff:bc
    inet 192.168.3.9 netmask 0xffffff00 broadcast 192.168.3.255
    member: vnet0.26 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
            ifmaxaddr 0 port 14 priority 128 path cost 2000
    member: vnet0.24 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
            ifmaxaddr 0 port 16 priority 128 path cost 2000
    member: em0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>            <----- here
            ifmaxaddr 0 port 6 priority 128 path cost 20000
    member: vnet0.19 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
            ifmaxaddr 0 port 12 priority 128 path cost 2000
    member: vnet0.18 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
            ifmaxaddr 0 port 13 priority 128 path cost 2000
    member: vnet0.16 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
            ifmaxaddr 0 port 11 priority 128 path cost 2000
    member: lagg0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
            ifmaxaddr 0 port 15 priority 128 path cost 10000
    groups: bridge
But that can be done automatically (separate to the network settings) if one of the jails or VMs is configured to defaults.
john.doe79
I've checked all Jails & VMs.
all are set to:
"none"
"vnet0"
"vnet0:bridge0"
either with DHCP or fixed IP.
seems to be gone now ...
have created bridge1 and did put em0 in it.
igb0: flags=8863<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
    description: LAN1
    options=8120b8<VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,WOL_MAGIC,VLAN_HWFILTER>
    ether a0:36:9f:20:a6:04
    media: Ethernet autoselect
    status: no carrier
igb1: flags=8822<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
    options=4e507bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,VLAN_HWFILTER,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6,NOMAP>
    ether a0:36:9f:20:a6:05
    status: no carrier
igb2: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
    options=4a500b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWFILTER,VLAN_HWTSO,RXCSUM_IPV6,NOMAP>
    ether a0:36:9f:20:a6:06
    media: Ethernet autoselect (1000baseT <full-duplex>)
    status: active
igb3: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
    hwaddr a0:36:9f:20:a6:07
    status: active
igb4: flags=8822<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
    ether b4:2e:99:31:9b:63
    status: active
em0: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
    description: management
    options=481009b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,VLAN_HWFILTER,NOMAP>
    ether b4:2e:99:31:9b:62
    status: active
    options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
    inet6 ::1 prefixlen 128
    inet6 fe80::1%lo0 prefixlen 64 scopeid 0x7
    groups: lo
pflog0: flags=0<> metric 0 mtu 33160
    groups: pflog
    member: vnet0.33 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
    groups: bridge
lagg0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
    description: Port 17 and 18
    laggproto lacp lagghash l2,l3,l4
    laggport: igb2 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING>
    laggport: igb3 flags=1c<ACTIVE,COLLECTING,DISTRIBUTING>
    groups: lagg
    status: active
vnet0.16: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
    description: associated with jail: mineos as nic: epair0b
    options=8<VLAN_MTU>
    ether b6:2e:99:c5:1d:5f
    hwaddr 02:1c:61:0b:a5:0a
    groups: epair
    status: active
vnet0.18: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
    description: associated with jail: tautulli as nic: epair0b
    options=8<VLAN_MTU>
    ether b6:2e:99:46:b0:16
    hwaddr 02:01:50:35:d5:0a
    groups: epair
    status: active
vnet0.19: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
    description: associated with jail: plexbeta as nic: epair0b
    options=8<VLAN_MTU>
    ether b6:2e:99:96:a3:59
    hwaddr 02:36:9a:7e:89:0a
    groups: epair
    status: active
vnet0.26: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
    description: associated with jail: myUsenetJail as nic: epair0b
    options=8<VLAN_MTU>
    ether b6:2e:99:ac:8f:4b
    hwaddr 02:6b:b1:a8:91:0a
    groups: epair
    status: active
vnet0.32: flags=8863<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
    description: associated with jail: dummyjail as nic: epair0b
    options=8<VLAN_MTU>
    ether b6:2e:99:87:9f:8b
    hwaddr 02:c4:a2:0e:39:0a
    inet 172.16.0.1 netmask 0xfffffffc broadcast 172.16.0.3
    groups: epair
    status: active
vnet0.33: flags=8963<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
    description: associated with jail: radarr as nic: epair0b
    options=8<VLAN_MTU>
    ether b6:2e:99:c1:df:ca
    hwaddr 02:a5:39:cd:69:0a
    groups: epair
    status: active
bridge1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
    description: Bridge Management
    ether 58:9c:fc:00:32:04
    inet 192.168.1.10 netmask 0xffffff00 broadcast 192.168.1.255
            ifmaxaddr 0 port 6 priority 128 path cost 55
    groups: bridge
