Stux
 - Jun 2, 2016
Hope so! The target version seems to be repeatedly getting pushed out...
Yes. Maybe you should second the feature request ;)
This might sound quite dumb, but I'm very new here (actually, to forums generally) so can you please tell me how to!Yes. Maybe you should second the feature request ;)
 log show --style syslog  --predicate 'senderImagePath contains[cd] "TimeMachine"' --info tail log stream --style syslog  --predicate 'senderImagePath contains[cd] "TimeMachine"' --info2017-11-15 11:27:07.946018+1100 localhost backupd[1817]: (TimeMachine) [com.apple.TimeMachine.TMLogInfo] Quota in effect for '/Volumes/Titan Time Machine': 4 TB (4,000,000,000,000 bytes)
-rw-r--r-- 1 timemachine wheel 225 Dec 31 13:03 .com.apple.TimeMachine.quota.plist -rw-r--r-- 1 timemachine wheel 0 Dec 31 13:03 .com.apple.TimeMachine.quota.plist.FreeNAS-managed -rw-r--r-- 1 timemachine wheel 0 Dec 31 13:03 .com.apple.timemachine.supported
Have you set a quota in the GUI, under Sharing/Apple(AFP)/<sharename>? If you set it as a TimeMachine share there is a box to enter a number which is treated as a number of GiB.Question about this. Under 11.1 I now have the following files:
Code:-rw-r--r-- 1 timemachine wheel 225 Dec 31 13:03 .com.apple.TimeMachine.quota.plist -rw-r--r-- 1 timemachine wheel 0 Dec 31 13:03 .com.apple.TimeMachine.quota.plist.FreeNAS-managed -rw-r--r-- 1 timemachine wheel 0 Dec 31 13:03 .com.apple.timemachine.supported
As you can see, the FreeNAS-managed version of the file is empty. Since I updated from 9.10, what is the best way to make sure the new quote option in FreeNAS 11 is utilized?
Thanks,
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"> <plist version="1.0"> <dict> <key>GlobalQuota</key> <integer>524288000</integer> </dict> </plist>
You are correct, it just works, as my .plist shows some random number for 1TB that I do not remember typing in like that.Have you set a quota in the GUI, under Sharing/Apple(AFP)/<sharename>? If you set it as a TimeMachine share there is a box to enter a number which is treated as a number of GiB.
If you have done that, then it should just work. And what I can confirm is that the result of ls -l in my share dataset is exactly the same as yours and the quota I have set is in the 225Byte .plist file. The fact that one of the files is described as "FreeNAS-managed" does not mean that this is the one FreeNAS has put the data in, it is presumably just an indicator, like a lock file.
This is the content of my .plist file, where 524288000 is my chosen 500GiB quota:
Code:<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"> <plist version="1.0"> <dict> <key>GlobalQuota</key> <integer>524288000</integer> </dict> </plist>
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"> <plist version="1.0"> <dict> <key>GlobalQuota</key> <integer>1048576000</integer> </dict> </plist>
Code:<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd"> <plist version="1.0"> <dict> <key>GlobalQuota</key> <integer>1048576000</integer> </dict> </plist>
Also interesting is in this plist, 1048576000 kilobytes = 0.9765625 TB... not exact. Both based on the "kilo is 1024" notation.
This functionality has now been included in FreeNAS 11.1 :)
