how to see truenas gui from another computer?
madvet
Hello! I made a clean truenas instalation ., into a desktop ... who is link to a router with lan cable .I see the truenas interface to my desktop ...but another laptop cant see.
How to resolve this ?
Thx !
Can you provide more information?
Router? Switch? Network configuration in TrueNAS? DHCP? IP whitelists?
There are many reasons this could be happening.
madvet
router Huawei from isp .... 2 switch between desktop and router . All ok . I can see the web gui page from my desktop .But i can do that from other device wifi .I dont made any change in network configurration . I made ..all from this video ....https://www.youtube.com/watch?v=WjLaK8yQAag&t=1s
ALl ok ..but my desire is to acces file and more ..from other device ..into and out from my network
Thx very much for your any help!
Aipoc76
Is your non connecting laptop able to ping the server? Are you on the same network?? Can you ping the router?
madvet
madvet
can ping to 192.168.1.1 (router) with laptop
How can know if is in the same network ? Sorry !
Aipoc76
can you ping the desktop?
Aipoc76
and screen snip the network summary tab
Davvo
If you want to access your system from outside your local network you need to use VPN tunnelling.
Aipoc76
fairly positive hes on LAN.
Davvo
Aipoc76
are you in a home. the laptop and desktop all connected to the same router? Or is the laptop located somewhere else?
Aipoc76
I understand this as from inside and outside my network.
Aye, but Im making the assumption that he was in initial stages of just getting it to work.
Aipoc76
Aipoc76
also open cmd prompt and do a "arp -a" then post results
Davvo
Since he's in the early stage understanding the requirements can help avoid wasting time.
madvet
ARP - a from my laptop
