I'm using proxmox and I provisioned a VM to run TrueNAS
I want to run qemu guest agent in TrueNAS
I refer to the following tutorial
www.truenas.com
www.truenas.com
But he still didn't run and threw the following error.
1673897458.357285: critical: failed to create guest agent channel
1673897458.357316: critical: failed to initialize guest agent channel
1673897654.194765: debug: disabling command: guest-suspend-disk
1673897654.194892: debug: disabling command: guest-suspend-ram
1673897654.194911: debug: disabling command: guest-suspend-hybrid
1673897654.194932: debug: disabling command: guest-set-vcpus
1673897654.194947: debug: disabling command: guest-get-memory-blocks
1673897654.194961: debug: disabling command: guest-set-memory-blocks
1673897654.195005: debug: disabling command: guest-get-memory-block-size
1673897654.195021: debug: disabling command: guest-get-memory-block-info
1673897654.195035: debug: disabling command: guest-fsfreeze-status
1673897654.195049: debug: disabling command: guest-fsfreeze-freeze
1673897654.195064: debug: disabling command: guest-fsfreeze-freeze-list
1673897654.195077: debug: disabling command: guest-fsfreeze-thaw
1673897654.195093: debug: disabling command: guest-fstrim
1673897654.195228: critical: error opening channel: No such file or directory
1673897654.195252: critical: error opening channel
1673897654.195266: critical: failed to create guest agent channel
1673897654.195279: critical: failed to initialize guest agent channel
Does anyone know how to fix this problem? Thank you.
Resource - Qemu Guest Agent for TrueNAS Core 13
A new build of all the tools for FreeBSD 13. Follow the existing great instructions for the previous version's build: https://www.truenas.com/community/resources/qemu-guest-agent.167/
Resource - QEMU Guest Agent
DISCLAIMER: Under no circumstances will I be held responsible or liable in any way for any claims, damages, losses, expenses, costs, or liabilities whatsoever (including, without limitation, any direct or indirect damages for loss of profits...
