[How-To] ownCloud using NGINX, PHP-FPM, and MySQL
tamilmad
Hi, you can easily install owncloud on a freebsd vm according to this guid on corral. I have done so an everything works good.
Edit:
Just use the freebsd 10 template, not freebsd 12
I created a docker for Nextcloud. When Iaccess the same, I get an error as below.
Can you help to overcome the same
Joshua Parker Ruehlig
I have been busy the last few months and haven't kept up with the comments here.
so does 'occ upgrade' no longer work? I'm on nextcloud 11.0.1 currently.
Thanks
EDIT
I tried using the phar method and kept hitting issues. tried the occ method and it worked as expected
ArgaWoW
Hi Joshua,
Nice to see you back in this tread.
I want to ask you, if you find some time, can you please update your how-to at the first page with an working php7-apcu version.
This would be really great.
Thanks in advance :)
Gesendet von meinem LG-H850 mit Tapatalk
Hi Joshua,
I think this command is what is needed.
make config-recursive install -C /usr/ports/devel/pecl-APCu
If this doesn't work maybe someone can tell me, thanks!
NasKar
I followed the directions by @KevDog on page 62 and everything worked great I can't renew my lets encrypt certificate in nextcloud. I get this error:
Attempting to renew cert from /usr/local/etc/letsencrypt/renewal/xxxx.ddns.net.conf produced an unexpected error: Failed authorization procedure. xxxx.ddns.net (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Could not connect to xxxx.ddns.net. Skipping.
In the past I didn't get an error if I ran /usr/local/bin/certbot renew --dry-run
Turns out I turned off port 80 forwarding to my server in my router as 443 was working with https. Letsencrypt need http: port 80 to renew. Hope this helps someone else.
ArgaWoW
Hello Joshua,
I have done a complet new installation with you command and it worked (I guess) I cant install php7-redis and I have trouble to get the cron job working (cron.php) I have installed nextcloud, not owncloud.
Can my cron-job-problem depend on the trouble with php7-redis? Also I get the message in admin screen "No php memory cache"
It would be realy nice if some one can help a little bit :)
Thank you
Hello Joshua,
Thank you
what does "pkg install php70-redis" tell you?
possibly the cron job is failing because the memory cache isn't available even though it is enabled. you could verify this by checking the logs or trying...
su -m www -c 'php -f /usr/local/www/owncloud/cron.php'
ArgaWoW
pkg: No packages available to install matching 'php70-redis' have been found in  the repositories
if I test the crown with you command it works.... but only this way.
btw.. me on freenas 9 nightlies....
I think this should work
make config-recursive install -C /usr/ports/databases/pecl-redis
hmm, how did you know cron was not working earlier? Do you think you entered the cron job correctly or did you have trouble with the 'vi' editor?
ArgaWoW
No, I don't have trouble with the cron job so far. Like I said I have done a completly new installation of "nextcloud" this morning. Please, find a hardcopy of my cron attached
Have tryed to install pecl-redis. This is what I get.
/usr/bin/make  all-recursive
--- all-recursive ---
Making all in glob
Making all in config
Making all in po
Making all in doc
--- ./make.info ---
restore=: && backupdir=".am$$" &&  am__cwd=`pwd` && CDPATH="${ZSH_VERSION+.}:" && cd . &&  rm -rf $backupdir && mkdir $backupdir &&  if (/bin/sh /usr/ports/devel/gmake/work/make-4.2.1/config/missing makeinfo --version) >/dev/null 2>&1; then  for f in ./make.info ./make.info-[0-9] ./make.info-[0-9][0-9] ./make.i[0-9] ./make.i[0-9][0-9]; do  if test -f $f; then mv $f $backupdir; restore=mv; else :; fi;  done;  else :; fi &&  cd "$am__cwd";  if /bin/sh /usr/ports/devel/gmake/work/make-4.2.1/config/missing makeinfo  -I .  -o ./make.info ./make.texi;  then  rc=0;  CDPATH="${ZSH_VERSION+.}:" && cd .;  else  rc=$?;  CDPATH="${ZSH_VERSION+.}:" && cd . &&  $restore $backupdir/* `echo "././make.info" | sed 's|[^/]*$||'`;  fi;  rm -rf $backupdir; exit $rc
/usr/ports/devel/gmake/work/make-4.2.1/config/missing: makeinfo: not found
WARNING: 'makeinfo' is missing on your system.
  You should only need it if you modified a '.texi' file, or
  any other file indirectly affecting the aspect of the manual.
  You might want to install the Texinfo package:
  <http://www.gnu.org/software/texinfo/>
  The spurious makeinfo call might also be the consequence of
  using a buggy 'make' (AIX, DU, IRIX), in which case you might
  want to install GNU make:
  <http://www.gnu.org/software/make/>
*** [./make.info] Error code 127
make[13]: stopped in /usr/ports/devel/gmake/work/make-4.2.1/doc
1 error
*** [all-recursive] Error code 1
make[12]: stopped in /usr/ports/devel/gmake/work/make-4.2.1
1 error
*** [all] Error code 2
make[11]: stopped in /usr/ports/devel/gmake/work/make-4.2.1
1 error
===> Compilation failed unexpectedly.
Try to set MAKE_JOBS_UNSAFE=yes and rebuild before reporting the failure to
the maintainer.
*** Error code 1
Stop.
make[10]: stopped in /usr/ports/devel/gmake
*** Error code 1
Stop.
make[9]: stopped in /usr/ports/devel/gmake
*** Error code 1
Stop.
make[8]: stopped in /usr/ports/misc/help2man
*** Error code 1
Stop.
make[7]: stopped in /usr/ports/misc/help2man
*** Error code 1
Stop.
make[6]: stopped in /usr/ports/print/texinfo
*** Error code 1
Stop.
make[5]: stopped in /usr/ports/print/texinfo
*** Error code 1
Stop.
make[4]: stopped in /usr/ports/devel/m4
*** Error code 1
Stop.
make[3]: stopped in /usr/ports/devel/m4
*** Error code 1
Stop.
make[2]: stopped in /usr/ports/devel/autoconf
*** Error code 1
Stop.
make[1]: stopped in /usr/ports/databases/pecl-redis
*** Error code 1
Stop.
make: stopped in /usr/ports/databases/pecl-redis
root@nextcloud:/ #
what I recommend is use 'pkg install' to install all those dependencies listed (gmake/help2man/...) then try the make command.
why did you earlier say you "I have trouble to get the cron job working", how did you know it was not working?
ArgaWoW
I dont understand what you mean i sould do now .... to to the installation from scratch? Sorry me from Germany and i have a litte problem to understand you this time :/
I know the cron dont work because the admin page of nextcloud "last cron job 35min. ago". It sould be between 15 min i guess :)
Again I will thank you for you help
try these commands
pkg install gmake help2man texinfo m4 autofconf
ahh, yeah that should show every 15 minutes. try fixing the redis issue first. then see if it starts working. or check your owncloud.log (possibly in /mnt/files)
ArgaWoW
try these commands
I could do all the commands exept of "pkg install autoconf"
try these commands
I have done
if I try
pkg install aufofconf
I get
pkg: No packages available to install matching 'autofconf' have been found in the repositories
But I guess
worked this time.
I tryed to enable Memcache in the config.php
'memcache.local' => '\\OC\\Memcache\\APCu',
I get
Memcache \OC\Memcache\APCu not available for local cache Is the matching PHP module installed and enabled?
if I go to the Nextcloud UI
I have done
if I try
I get
But I guess
worked this time.
I get
ohh, that was a typo, should have been 'autoconf'
did you install APCu like in the instructions? I updated it less than 24 hours ago so maybe the correct step wasn't there yet.
ArgaWoW
I have done
and I get
The most recent version of packages are already installed
I have done
according to the first page. So I guess I have installed APCu
ArgaWoW
The next problem I have. When I restard the jail, I must do
service nginx start && service php-fpm start && service mysql-server start && service redis start
manually. They don't autostart.
I guess something is going very wrong while the installation. Should I try to do a complete new one to solve all this problems?
You can check pecl-APCu is installed with 'pkg info'
you can also verify apcu is available to PHP by creating an phpinfo file in /usr/local/www/owncloud/updater
they should start if you enabled them with the sysrc command.
what does 'cat /etc/rc.conf' show?
I personally would just fix the issues, but if reinstall sounds better to you you can do it.
ArgaWoW
Ok, lets try to fix it :)
This is the output of pkg info:
apr-1.5.2.1.5.4_2  Apache Portability Library
autoconf-2.69_1  Automatically configure source code on many Un*x platforms
autoconf-wrapper-20131203  Wrapper script for GNU autoconf
ca_root_nss-3.30.1  Root certificate bundle from the Mozilla Project
curl-7.53.1_1  Non-interactive tool to get files from FTP, GOPHER, HTTP(S) servers
cvsps-2.1_2  Create patchset information from CVS
db5-5.3.28_6  Oracle Berkeley DB, revision 5.3
dialog4ports-0.1.6  Console Interface to configure ports
expat-2.2.0_1  XML 1.0 parser written in C
freetype2-2.7.1  Free and portable TrueType font rendering engine
gdbm-1.12  GNU database manager
gettext-runtime-0.19.8.1_1  GNU gettext runtime libraries and programs
gettext-tools-0.19.8.1  GNU gettext development and translation tools
git-2.12.1  Distributed source code management tool
gmake-4.2.1_1  GNU version of 'make' utility
help2man-1.47.4  Automatically generating simple manual pages from program output
icu-58.2_1,1  International Components for Unicode (from IBM)
indexinfo-0.2.6  Utility to regenerate the GNU info page index
jpeg-turbo-1.5.1  SIMD-accelerated JPEG codec which replaces libjpeg
kbproto-1.0.7  KB extension headers
libICE-1.0.9_1,1  Inter Client Exchange library for X11
libSM-1.2.2_3,1  Session Management library for X11
libX11-1.6.5,1  X11 library
libXau-1.0.8_3  Authentication Protocol library for X11
libXaw-1.0.13,2  X Athena Widgets library
libXdmcp-1.1.2  X Display Manager Control Protocol library
libXext-1.3.3_1,1  X11 Extension library
libXmu-1.1.2_3,1  X Miscellaneous Utilities libraries
libXp-1.0.3,1  X print library
libXpm-3.5.12  X Pixmap library
libXt-1.1.5,1  X Toolkit library
libffi-3.2.1  Foreign Function Interface
libgcrypt-1.7.6  General purpose crypto library based on code used in GnuPG
libgpg-error-1.27  Common error values for all GnuPG components
libiconv-1.14_10  Character set conversion library
libltdl-2.4.6  System independent dlopen wrapper
libmcrypt-2.5.8_3  Multi-cipher cryptographic library (used in PHP)
libnghttp2-1.21.1  HTTP/2.0 C Library
libpthread-stubs-0.4  This library provides weak aliases for pthread functions
libxcb-1.12_2  The X protocol C-language Binding (XCB) library
libxml2-2.9.4  XML parser library for GNOME
libxslt-1.1.29_1  The XSLT C library for GNOME
libzip-1.1.3  C library for reading, creating, and modifying ZIP archives
m4-1.4.18,1  GNU M4
mariadb101-client-10.1.22_1  Multithreaded SQL database (client)
mariadb101-server-10.1.22_1  Multithreaded SQL database (server)
nginx-1.10.3_1,2  Robust and small WWW server
oniguruma5-5.9.6_1  BSDL Regular Expressions library compatible with POSIX/GNU/Perl
p5-Authen-SASL-2.16_1  Perl5 module for SASL authentication
p5-Digest-HMAC-1.03_1  Perl5 interface to HMAC Message-Digest Algorithms
p5-Error-0.17024  Error/exception handling in object-oriented programming style
p5-GSSAPI-0.28_1  Perl extension providing access to the GSSAPIv2 library
p5-Locale-gettext-1.06  Message handling functions
pcre-8.40  Perl Compatible Regular Expressions library
pecl-APCu-5.1.8  APC User Caching
pecl-redis-3.1.1  Extension to access Redis
perl5-5.24.1_1  Practical Extraction and Report Language
php70-7.0.17  PHP Scripting Language
php70-bz2-7.0.17  The bz2 shared extension for php
php70-ctype-7.0.17  The ctype shared extension for php
php70-curl-7.0.17  The curl shared extension for php
php70-dom-7.0.17  The dom shared extension for php
php70-exif-7.0.17  The exif shared extension for php
php70-fileinfo-7.0.17  The fileinfo shared extension for php
php70-filter-7.0.17  The filter shared extension for php
php70-gd-7.0.17  The gd shared extension for php
php70-hash-7.0.17  The hash shared extension for php
php70-iconv-7.0.17  The iconv shared extension for php
php70-intl-7.0.17  The intl shared extension for php
php70-json-7.0.17  The json shared extension for php
php70-mbstring-7.0.17  The mbstring shared extension for php
php70-mcrypt-7.0.17  The mcrypt shared extension for php
php70-openssl-7.0.17  The openssl shared extension for php
php70-pdo-7.0.17  The pdo shared extension for php
php70-pdo_mysql-7.0.17  The pdo_mysql shared extension for php
php70-posix-7.0.17  The posix shared extension for php
php70-session-7.0.17  The session shared extension for php
php70-simplexml-7.0.17  The simplexml shared extension for php
php70-wddx-7.0.17  The wddx shared extension for php
php70-xml-7.0.17  The xml shared extension for php
php70-xmlreader-7.0.17  The xmlreader shared extension for php
php70-xmlwriter-7.0.17  The xmlwriter shared extension for php
php70-xsl-7.0.17  The xsl shared extension for php
php70-zip-7.0.17  The zip shared extension for php
php70-zlib-7.0.17  The zlib shared extension for php
pkg-1.10.1  Package manager
png-1.6.29  Library for manipulating PNG images
printproto-1.0.5  Print extension headers
python27-2.7.13_1  Interpreted object-oriented programming language
readline-6.3.8  Library for editing command lines as they are typed
redis-3.2.8  Persistent key-value database with built-in net interface
serf-1.3.9_1  Serf HTTP client library
sqlite3-3.18.0  SQL database engine in a C library
subversion-1.9.5  Version control system
t1lib-5.1.2_4,1  Type 1 font rasterization library for Unix/X11
texinfo-6.1.20160425_1,1  Typeset documentation system with multiple format output
xextproto-7.3.0  XExt extension headers
xproto-7.0.31  X11 protocol headers
Seems It is installed.
This is my rc.conf
ortmap_enable="NO"
sshd_enable="NO"
sendmail_enable="NO"
sendmail_submit_enable="NO"
sendmail_outbound_enable="NO"
sendmail_msp_queue_enable="NO"
hostname="nextcloud"
devfs_enable="YES"
devfs_system_ruleset="devfsrules_common"
inet6_enable="YES"
ip6addrctl_enable="YES"
nginx_enable="YES"
php_fpm_enable="YES"
mysql_enable="YES"
redis_enable="YES"
looks good.
Sorry, I dont know how to create the php.info file :/
