[How-To] ownCloud using NGINX, PHP-FPM, and MySQL
Joshua Parker Ruehlig
Thank you sir, I'll try that right now...
I kept going and I'm stuck on the last 3 steps, I don't see where those options are on the 'Frondend" tab....
View attachment 9091 View attachment 9092
EDIT +++++++++++++++++++++++++++++++++++++
So there is a "Template" tab, that had the the frontend and bacnend temapltes for Startcom SSL...so I used that and i can see those options, however after selecting the Created CAs, i get the following errors...
Errors found while starting haproxy
[ALERT] 297/205335 (98765) : parsing [/var/etc/haproxy_test/haproxy.cfg:10] : 'bind 73.237.25.197:443' : unable to load SSL private key from PEM file '/var/etc/haproxy_test/HAProxy_stats_ssl_frontend.pem'.
[ALERT] 297/205335 (98765) : Error(s) found in configuration file : /var/etc/haproxy_test/haproxy.cfg
[ALERT] 297/205335 (98765) : Proxy 'HAProxy_stats_ssl_frontend': no SSL certificate specified for bind '73.237.25.197:443' at [/var/etc/haproxy_test/haproxy.cfg:10] (use 'crt').
[ALERT] 297/205335 (98765) : Fatal errors found in configuration.
Any help, or guide where to start looking would be appreciated
Here's the bottom of my frontend tab
Maturola
Thank you, I tried everything and I cannot saved the changes.
It seen to be an issue with binding the public IP with port 443. If I remove port 443 from the frontend it let me saved the changes.
I think I'm just going to give up on HAproxy and try to configure the SSL at Owncloud ...
is pfsense running on 443? 'sockstat | grep 443' would show if something else is binding to that socket.
I checked, pfsense was running on 443, however i still get same error even after changing the port for webconfigurator =(
did you check sockstat on pfsense?
if you still want to get this working you could ask on the pfsense forum, the dev for the HAProxy plugin (PiBa) is very resposive.
Maturola
Yes, I ran Sockstat, nothing comes back for 443 ..
I think its something wrong with the SSL, most likely a "operators" error. .... no big deal i'll try configuring it on owncloud itself see if that works .
Thanks
Thanks
no prob, yeah it's tricky to get the certs setup right. goodluck.
I wonder if it's because you didn't check the (SSL Offloading) on the frontend tab. noticed mine is checked.
Maturola
ownCloud WebUI (http://jailip/owncloud)
Advanced
  • Data folder = /mnt/files
  • Configure the database = MySQL/MariaDB
  • Database user = ocuser
  • Database password = ocpass
  • Database name = owncloud
  • Database host = localhost:/tmp/mysql.sock
Console in jail's userland
'memcache.local' => '\OC\Memcache\APCu',
So back to the real theme of the threat........
I followed the step by step and I'm stuck on this section the WebUI of owncloud, it seen like it is still running Sqlite3.
After all the steps, when i went to the webui - http://<Jail IP>/owncloud all it asked me was to setup my user name and password and no "advanced' option anywhere.
what am I missing?
what am I missing?
did you already enter those in? if so then it already set things up with sqlite.
there should be a small arrow that you press and gives you the advanced options below the username/password. including the dstadirectory and database info.
here's a random picture I found showing the setup screen
https://www.howtoforge.com/images/owncloud_5.0_nginx_debian_wheezy_ubuntu_13.10/1.png
Maturola
No, this was a brand new jail, and first time ever I went to the wedUI...for some reason it seen like it was already there. Not idea =( I;m having such a bad luck with all this setup
what was already there? if you already passed this step you can just run the below and do it again
rm -r /usr/local/www/owncloud/data/* /usr/local/www/owncloud/config/config.php
Maturola
Ok that allow me move one step forward...however i;m getting the follwing error once i click "Finish Setup"
Error while trying to create admin user: Failed to connect to the database: An exception occured in driver: SQLSTATE[HY000] [2002] Can't assign requested address
others have reported a similar issue with OC8.2. I believe it's a bug with the database host parsing. try using "localhost"
