We have no idea as you have failed to post both your hardware and even what version of TN you are using.
Please see forum rules!
The effect of spinning down HDD's is widely discussed with little consensus as to whether its a good idea or not. Constant spinning down and up put extra wear and tear on the drives, shortening their life (probably). If however you only access your drives once a day then spinning down probably makes sense. There must be a break even point somewhere where the extra wear and tear is balanced by the reduced cost- but no-one knows where it is
