HOW-TO: NextCloud 10 w/ Apache, PHP, and MariaDB
techmod
Hi again!
Look at my guide again, the SSL cert and cipher info all belongs under <VirtualHost*:443>
I have configured my config again and inserted a self signed ssl certificate. Works pretty well now, but only in LAN.
is some config in my fritzbox wrong ?
I have the freenas box on LAN 4, connected over eth0. The nextcloud jail within freenas is also on LAN4. When I nmap (btw I use ArchLinux as my daily driver) the box internally it shows open ports 80 for http, 84 for ssh, 443 for https and 3306 for mysql.
When I nmap from outside it doesnt find anything. Fritzbox is forwarded on 443. Maybe an issue with dyndns? I don´t use it.
nathank1989
Hi again!
I am from the US so I am quite unfamiliar with Fritzbox. Only thing I can suggest based off your posts is that your router(fritzbox) is not configured to accept outside https connections.
If https works on LAN but not WAN that's usually a router/gateway problem.
Make sure you have port forwarding/triggering enabled and forwarded to your internal LAN address of the JAIL, not the FreeNAS itself. Also check any firewall settings on the router too. Maybe try putting the jail in a DMZ temporarily to test connections. If you still can't connect, you'll have to research how your ISP handles remote access.
snaptec
Which Provider?
Maybe unitymedia, they use dslite so natted IPv4 and native ipv6
Gesendet von iPhone mit Tapatalk
techmod
No, 1&1 they don´t block anything. i called them yesterday. i will try the nat function.
JWTech
Personally, I despise vi, but this is the quickest method I have found. Know a way better, please let me know.
if you don't know how to use vi, here's a quick step by step. I suggest you check out this cheat sheet
Reason we don't use nano here is because keys like ctrl+x do not work in the shell applet used in FreeNAS GUI. We have to use a real terminal like PuTTY to use a nano properly.
  1. Scroll down using the DOWN arrow key until you find #PermitRootLogin no line.
  2. With the cursor on the # hit x this will delete the hash now use the RIGHT arrow key to select the space before 'no'
  3. Hit i type yes
  4. Hit esc
  5. Select the n in 'no' and hit x twice to delete 'no' so the line reads PermitRootLogin yes
  6. type :wq
  7. Hit ENTER
  8. The file is now saved
Use ee to make the edit (I use it when I can't use nano), then just hit ESC then follow the prompt to exit the file and save.
Or just run sed -i '' 's/#PermitRootLogin no/PermitRootLogin yes/g' /etc/ssh/sshd_config and that will auto-replace the text.
Could also SSH into the main system, then "jexec" nano, or just nano the file from outside the jail, restart the jail when saved, then SSH into the jail.
nathank1989
I forgot about sed, I don't use it often. I'll look into ee I've actually never heard of it.
And I didn't learn about jexec until after I wrote this, really my first stint using FreeNAS so I'm still learning new things.
To simplify steps, I'll probably just replace those steps with the sed command
Keuj
Thanks a lot for your post Nathan, I successfully intall nextcloud this evening
techmod
Hi again!
I had to set everything up new. So i had to follow your guide anew. Now I am facing the problem (which was no problem before), that when I want to retrieve the certificate from certbot it cannot connect to my IP (http-01). Here´s a screenshot of it:
Lazulitone
Thanks everyone for this guide. I was able to get my nextcloud instance running, however, when trying to get SSL to work I ran into a bump:
after running:
cd /usr/ports/www/apache24/
make deinstall
make install clean
Apache won't start/restart...
root@nextcloud:/usr/local/www/apache24/data # service apache24 start
apache24 does not exist in /etc/rc.d or the local startup
directories (/usr/local/etc/rc.d)
Any ideas how to restore this? I tried a dynamic link to the apache24 dir but I don't have permissions to run it this way.
Thanks!
nathank1989
after running:
make deinstall
make install clean
Thanks!
Try
$ sysrc apache24_enable=yes
Lazulitone
Try
Thanks Nathan for your speedy response... Didn't work.
root@nextcloud:~ # sysrc apache24_enable=yes
apache24_enable: yes -> yes
root@nextcloud:~ # service apache24 start
Lazulitone
root@nextcloud:/usr/ports/www/apache24 # apachectl -v
apachectl: Command not found.
root@nextcloud:/usr/ports/www/apache24 # cd
root@nextcloud:~ # apachectl -v
I'm afraid I'm lost. It's as though the new package from make install clean Apache washed away all the system references to the installation.
nathank1989
Did you run into any errors while compiling Apache from ports? Try recompiling* again. It sounds like Apache isn't even installed.
Try this
portsnap fetch
portsnap extract
portsnap update
make install clean
I would also highly suggest recompiling openssl per instructions after updating the ports tree before you do Apache
nathank1989
Hi again!
That is usually a connectivity problem. From my understanding you need a Fully Qualified Domain Name pointed to a valid DNS for certbot to work. Mine wouldn't work until my domain fully propagated. Google DNS propagation checker and type in your domain, if it's all green then I'm afraid someone else or Google will have to help you. Certbot does NOT work with raw IP addresses (at least when I tried)
Jailer
Not strong, but bad
Quick question for all installing this. Why not just use the pkg version of nextcloud and mysql? Seems like it would be easier to keep up to date via pkg if you do.
nathank1989
When I first did this, pkg install nextcloud didn't work for me, so I did it manually. You can upgrade using the updater within the Web UI. I never noticed it was in the ports tree until recently.
Correct me if I am wrong, but I also thought what's available in the ports/repo isn't always the freshest version available from nextcloud.com
But if it works and it's easier, by all means do it that way. ;)
Jailer
Not strong, but bad
Ports and packages get updated albeit at a slightly slower pace than the source files. It all depends on the maintainer. Using the nextcloud package would make for easier upgrades as dependencies are handled via pkg.
Don't get me wrong, I'm not knocking a manual install, just looking to entertain some discussion.
I did and it was or I wouldn't have posted this. ;)
This is not working for me on my manual nextcloud install hence why I pursued the nextcloud package install.
techmod
I know that, thank you. It worked with my previous install (same IP, same domain, same setup). Hmmm. Thanks for your work and thoughts.
nathank1989
There was a known issue in 10.0 Stable that used Owncloud's updater and version. So if you open the updater it will say: Owncloud 9.1.1 when technically you're on Nextcloud 10.0 Stable. This prevents the updater from working so (unless you used pkg) you will need to manually upgrade.
10.0.1 is the version I am running, and the plan is after this release, anyone can update via the updater app like you would with say, wordpress. This was my ultimate goal, but was disappointed when I saw the issues in 10.0 STABLE.
Either way, glad you got it working.
