How to mount NTFS/Raid5 after upgrade
kwaugh
Hello.
I just upgraded from .7 to 8.2.
The NAS had a SW Raid 1 of two disks and a SW Raid 5 of 3 disks.
I was able to auto import the Raid 1 after upgrade with no problem.
My question is how do I mount the Raid5 disks and restore them.
When I try to mount one of the disks from the set, I get "an error occurred while labeling the disk".
My question is two part:
how do I mount the disks?
how do I go about reconstructing the Raid5 set?
I have an external drive available that I could use to copy the files from the set (would need help on how to accomplish this), if it's not straight forward to mount/recreate the set.
Many thanks.
paleoN
You don't. FreeNAS 8 doesn't support RAID5 as discussed in this [post=30787]thread[/post].
