How to modify shell blurb
Eric999
In TrueNAS 12, when I click on Shell, I get the following:
Last login: Sun Jan 3 21:15:40 on pts/0 FreeBSD 12.2-RELEASE-p2 663e6b09467(HEAD) TRUENAS TrueNAS (c) 2009-2020, iXsystems, Inc. All rights reserved. TrueNAS code is released under the modified BSD license with some files copyrighted by (c) iXsystems, Inc. For more information, documentation, help or support, go here: http://truenas.com
and then the command prompt. I would like to modify the above blurb to mention the /etc/netcli command which displays the menu because I keep forgetting it. :)
You might be able to do that through System | Advanced | MOTD ...
Eric999
