There shoul be option 1 or 2 to confirm that you agree. If succesfull you should see message saying that.
Yes.
I changed to 7.2, and it works.
You did not finish letsencrypt part, bu also check does your virtual host config file has .conf extension?
after your reply it did take me a bit further. after i agreed it gave me this.
Obtaining a new certificate
Performing the following challenges:
http-01 challenge for xxxx.asuscomm.com
Using the webroot path /usr/local/www/apache24/data/nextcloud for all unmatched domains.
Waiting for verification...
Cleaning up challenges
Failed authorization procedure. xxxx.asuscomm.com (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://xxxx.asuscomm.com/.well-known/acme-challenge/_RkscEzcKw0vNIyyylfsJtIxvQjM_gS6QVg7gBAnkIc: "<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>404 Not Found</title>
</head><body>
<h1>Not Found</h1>
<p"
IMPORTANT NOTES:
- The following errors were reported by the server:
Domain: xxxx.asuscomm.com
Type: unauthorized
Detail: Invalid response from
http://xxxx.asuscomm.com/.well-known/acme-challenge/_RkscEzcKw0vyylfsJtIxvQjM_gSg7gBAnkIc:
<html><head>
</head><body>
<h1>Not Found</h1>
<p"
To fix these errors, please make sure that your domain name was
entered correctly and the DNS A/AAAA record(s) for that domain
contain(s) the right IP address.
- Your account credentials have been saved in your Certbot
configuration directory at /usr/local/etc/letsencrypt. You should
make a secure backup of this folder now. This configuration
directory will also contain certificates and private keys obtained
by Certbot so making regular backups of this folder is ideal.
