Mark_the_Red
- May 3, 2017
The MineOS plugin is broken now so I expect this thread to get a lot more traffic.
pkg: No packages available to install matching 'sysutils/rdiff-backup' have been found in the repositories
pkg install doesn't take the category prefixes like "www/" so it's supposed to be pkg install rdiff-backup.pkg search rdiff, to name one example.pkg: No packages available to install matching 'rdiff-backup' have been found in the repositories
colordiff-1.0.19 Tool to colorize diff output dirdiff-2.1_4 Graphical diff tool py37-rdiff-backup-2.0.0 Easy to use and efficient backup and restore utility
pkg install py37-rdiff-backup, drop the version number when installing.Will have a look at what I done wrong now :)
I updated the instructions in the first post.
Regarding the plugin, see this post: https://www.truenas.com/community/threads/mineos-installation-error.87920/#post-610751
ssh <user>@<ip address> at a command prompt.iocage console <myjailname>.My last question, is with regards to your original post #1 when creating the jail you set the iocage nat_forwards. Are these the only ports that will work with the Minecraft server.
