[How-to] Install ffmpeg in a jail
vinchi007
I dont understand why pkg-config complains that there is no x265. pkg-config print shows that .pc is there along with .so lib
pkg-config --exists --print-errors x265
Glorious1
@Dakai, @vinchi007
I completely redid the first post with all new instructions, using only the built-in compiler clang. Also using git and hg version systems whenever possible so you don't have to go looking at websites to see if there are new versions when you want to update the install. Just tested it all with a new jail on FreeNAS 11.1.
By the way, unlike a default install with pkg, x264 and x265 programs are available for direct use as well as their --help systems.
EsTaF
If a speex decoding needed>
(ffmpeg -i 2049.flv -y -hide_banner -movflags +faststart -c:v copy -c:a aac -b:a 192k converted/test.mp4
Decoder (codec speex) not found for input stream #0:1)
pkg install speex
cd /builds/ffmpeg
gmake clean
./configure --cc=/usr/bin/clang --pkg-config-flags="--static" --enable-static --disable-shared --enable-nonfree --enable-gpl --enable-version3 --enable-hardcoded-tables --enable-libfdk-aac --enable-libx264 --enable-libx265 --enable-avfilter --enable-filters --disable-indevs --disable-outdevs --disable-network --enable-libfreetype --enable-libfontconfig --enable-libfribidi --enable-libspeex
gmake
gmake uninstall
gmake install
gmake clean
./configure --cc=/usr/bin/clang --pkg-config-flags="--static" --enable-static --disable-shared --enable-nonfree --enable-gpl --enable-version3 --enable-hardcoded-tables --enable-libfdk-aac --enable-libx264 --enable-libx265 --enable-avfilter --enable-filters --disable-indevs --disable-outdevs --disable-ffserver --disable-network --enable-libfreetype --enable-libfontconfig --enable-libfribidi
Following your (outstanding, phenomenal) tutorial, just got this error while trying to run this above command:
Unknown option "--disable-ffserver".
See ./configure --help for available options.
I removed this flag and all went fine.
Thanks a lot for this major contribution!
Matías.-
Glorious1
Matías.-
Thanks Matías. I'm surprised it worked as well as it did. Several of the libraries now have new build tools and methods, and my sequence has gradually evolved to keep up with them (including removing --disable-ffserver). I updated the first post with the new stuff. This should ensure that new builds are using the latest versions of everything.
HJD
Adding to this thread...for those that are interested in a tested and automated version of these instructions, I’ve created a quick script on Github: https://github.com/hjdhjd/build-ffmpeg that should work right out of the box.
Download the script in a new jail and run it. It’ll prompt if there are missing dependencies. Note: the version of ffmpeg it compiles is slightly different than this one, as I have enabled network support, as well as support for opus and SoX codecs.
@Glorious1 - most of the credit goes to you here. I just automated a few things and streamlined a bit. Thanks for a great contribution to the community!
Enjoy!
Glorious1
Wow, that's quite a professional-looking script! And fast work.
One update on compiling pkg-config, I found how to specify the target. So you could add to the autogen command:
--prefix="$TARGET" --exec-prefix="$TARGET"
Then it's a bit cleaner, everything gets built in the same place.
Also, I was wondering, since you're running a script, can you just put the commands from the edited multilib.sh directly in your script? Then you don't have to go through the editing and calling. But of course end result will be the same.
asmodeus
Enjoy!
That's great! I've also (independently - great minds think alike!) created a version to help with my automatic setup based on jailman. Leaving the script here, stay tuned for the jailman part.
#!/usr/bin/env bash
# This is based on a script by Glorious1 and HJD from
# https://www.ixsystems.com/community/threads/how-to-install-ffmpeg-in-a-jail.39818/
# It was modified to build on 11.3 and run without user input by asmod3us.
set -o errexit   # Exit on most errors
set -o errtrace  # Make sure any error trap is inherited
set -o nounset   # Disallow expansion of unset variables
set -o pipefail  # Use last non-zero exit code in a pipeline
trap "ERR during ffmpeg build" ERR
CORES=$(sysctl -n hw.ncpu)
# see config.yml for packages
export CC=/usr/bin/clang
export CXX=/usr/bin/clang++
export PATH=$PATH:/usr/local/share
export PKG_CONFIG_PATH=/usr/local/lib:/usr/local/lib/pkgconfig:/usr/local/libdata/pkgconfig
BUILD=$(mktemp -d -t ffmpeg)
TARGET=/usr/local/ffmpeg
export PATH=$PATH:${TARGET}/bin
rm -f /usr/local/lib/libavcodec* /usr/local/lib/libx2*
mkdir -p "${BUILD}" ${TARGET}
git clone --depth 1 https://github.com/mstorsjo/fdk-aac "$BUILD"/fdk-aac/
git clone --depth 1 https://anongit.freedesktop.org/git/pkg-config "$BUILD"/pkg-config/
git clone --depth 1 http://git.videolan.org/git/x264.git "$BUILD"/x264/
hg clone http://hg.videolan.org/x265 "$BUILD"/x265/
git clone --depth 1 https://git.ffmpeg.org/ffmpeg.git "$BUILD"/ffmpeg/
cd "$BUILD"/fdk-aac
# There is no configure file anymore so have to make it with autoreconf
autoreconf -fiv && \
./configure --prefix="$TARGET" --disable-shared && \
make -j"$CORES" && \
make install
cd "$BUILD"/pkg-config
sed -i '' -e 's/m4_copy(/m4_copy_force(/' glib/m4macros/glib-gettext.m4
./autogen.sh --with-internal-glib --prefix="$TARGET" --exec-prefix="$TARGET"
make -j"$CORES" install clean
export PKG_CONFIG_PATH=$PKG_CONFIG_PATH:$TARGET/lib/pkgconfig
cd "$BUILD"/x264
sed -i '' -e 's|#\!/bin/bash|#\!/usr/bin/env bash|' configure
./configure --prefix=$TARGET --enable-static --enable-pic
gmake -j"$CORES"
gmake install clean
cd "$BUILD"/x265/build/linux
# shellcheck disable=SC2016
sed -i '' -E \
-e '/cd 12bit/,/cmake/ s|^cmake|cmake -D CMAKE_C_COMPILER=/usr/bin/clang -D CMAKE_CXX_COMPILER=/usr/bin/clang++|' \
-e '/cd \.\.\/8bit/,/cmake/ s|^cmake \.\./\.\./\.\./source|cmake -DCMAKE_INSTALL_PREFIX=/usr/local/ffmpeg/ ../../../source -DENABLE_SHARED=OFF|' \
-e 's/cmake/cmake -j'"$CORES"'/' \
-e 's/(if \[ "\$uname" = "Linux" \])/\1 | [ "$uname" = "FreeBSD" ]/' multilib.sh
./multilib.sh
cd 8bit
cp -v ${TARGET}/lib/libx265* /usr/local/lib
cd "$BUILD"/ffmpeg
export CFLAGS="-I${TARGET}/include -I/usr/local/include -I/usr/include"
export LDFLAGS="-L${TARGET}/lib -L/usr/local/lib -L/usr/lib"
export PKG_CONFIG_PATH=${TARGET}/lib:$TARGET/lib/pkgconfig:${PKG_CONFIG_PATH}
./configure prefix=$TARGET --cc=/usr/bin/clang \
--extra-cflags="-I$TARGET/include" --extra-ldflags="-L$TARGET/lib" \
--extra-libs=-lpthread \
--pkg-config-flags="--static" \
--enable-static --disable-shared --enable-libfdk-aac --enable-libx264 \
--enable-libx265 --enable-libfreetype --enable-libfontconfig \
--enable-libfribidi --enable-nonfree --enable-gpl --enable-version3 \
--enable-hardcoded-tables --enable-avfilter --enable-filters --disable-outdevs \
--disable-network --enable-libopus --enable-libsoxr
gmake -j"$CORES"
gmake install
HJD
@Glorious1 - thanks! I've made a couple of updates to the script to reflect that. Feel free to provide pull requests to improve it too. Really appreciate all your hard work here.
@asmodeus - great minds indeed! Well done. Feel free to merge into mine (or merge mine into yours) to the extent it makes sense. I'm glad to see others provide resources to automate this!
asmodeus
@HJD Thanks, I'm inspired by your script and will merge a few things. I'll put it on GitHub as a PR for jailman once forked-daapd builds.
ornias
Speaking of the devil (me), my first thoughts where also "I want to do something with this"....
Looking forward to your work! ^^
Glorious1
For you guys making scripts, just be aware they may need occasional maintenance. At least in the past, installation of the libraries has changed every few months or so. I guess that's why I never pursued a script. Babysitting it I can see right away if something needs troubleshooting.
ornias
Thats the nice thing of JailMan, it's designed to make jails throw-away-able. :)
I think thats also why @asmodeus wanted to port it...
Glorious1
A working updated tutorial would be much appreciated (fdk-aac needed)
Attached is a procedure that worked well for me as of TrueNAS 12.2 in Feb. 2022. I didn't actually try it in 13 yet, but I'm sure it will work. If you follow it, let me know if something fails.
Edit: see next post for updated instructions.
Glorious1
Pimmp, I actually went through all the steps today, starting with creating the jail from scratch. There are a couple of minor changes/corrections and updates to some build commands. Attached.
  • ffmpeg_build_on_FreeNAS_2022-07-27.txt
